Bird. It's the word...
Fishcop's Avatar
Flywheel Bolt Alternatives
I've just forked out hefty coin for some fairly ordinary looking bolts - apart from the obvious 12 point bit required to wind 'em up.
There is a significant difference in price between the bolts used in the 6 bolt and 9 bolt flywheels. And I frankly can't work out the difference in quality or manufacture specs.
Has anyone ever used quality allen headed bolts or even standard headed bolts as an alternative to these $10 jobbies?
John Forcier
Current: 68L 2.0 Hotrod - build underway
Old 10-17-2005, 12:49 AM
Well the bolts are made to stretch at a certain torque and stay firm. I wouldn't trust any old hardware to hold on the flywheel. If any of those bolts even get loose bad things can happen......would you use any old bolts to hold on the heads to an engine?
Kevin
2000 Boxster S
2013 Golf R
1999 911 C2 Aero
Old 10-17-2005, 04:06 AM
Fishcop's Avatar
I did a fair bit of searching on the board and there is clearly two camps. Apparently the bolts are not stretch bolts and Porsche says they can be reused. Several of the reputable builders on this board reuse them... That got me to thinking that there should be other high quality fastners out there of the same quality and surely less that the 10 to 15 dollars currently asked by Porsche.
I agree, I am not prepared to be a bunny, and I am going with new factory bolts; but I thought a few of the racers out there might have come up with alternatives.
John Forcier
Old 10-17-2005, 04:33 AM
I also looked for a cheaper bolt. I couldn't find one. I would reuse the 9 bolts but not the 6 bolts. Maybe we should just be happy that we can still get the bolts from Porsche
Dean
Dean
911 SC turbo, 3.0L 930 motor, G50, 930 brakes, DTA EFI, 352 RWHP DynoDynamic dyno,
Old 10-17-2005, 04:38 AM
randywebb's Avatar
There are not two camps but two types of bolts. Check the factory workshop manual and you'll see that they discontinued the stretch bolts in the late 1970's.
I would never use a cheapo bolt - the bolts are hardened and very precisely made (well, not compared the things in aerospace, nuclear bombs, etc.). You don't want the flywheel to come off.
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 10-17-2005, 10:10 AM
Fishcop's Avatar
Thanks Randy, that clarifies it. As I said, I'd go with the correct factory bolts, but I just have trouble accepting that the earlier bolts are 10 times the quality of the later versions
John Forcier
Old 10-17-2005, 04:41 PM
randywebb's Avatar
yeh - and maybe they aren't -- you are paying a risk premium
just like in an insurance policy
Old 10-17-2005, 05:12 PM
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
