Cigars and 911's -- Smile
acapella8's Avatar
Send a message via AIM to acapella8
78SC Euro "Turn Signal Relay" Question...
(I ordered a Bentley Service Manual for help on this electrical question, but it hasn't shipped yet...)
Can another 78SC owner confirm if the turn signal switch (or realy as it were) should have 3 or 4 prongs?
I refer to the switch located in front that controls turn signal blinkers. I bought one from another vendor (not Pelican, shame on me) that was 3 pronged, and it did not work (although it was slated to work in my 78 911 SC)
My old switch (that works) has 4 prongs.
The new switch (that doesn't work) only has 3.
Could the Euro models be different in this regard?
Here's a pic of the 3 pronged that did NOT work:
[GruppeB # 978]
1978 911 SC ROW (Pure Euro, no DOT or EPA work done..)
1991 Toyota MR2 Turbo (3S-GTE 4Banger Rocket)
2001 Audi - A6 Quattro 4.2L-V8 (love the growl)
2014 Honda Odyssey for the soccer-team/accessories
Old 10-17-2005, 12:58 PM
acapella8's Avatar
Bump.
[GruppeB # 978]
Old 10-17-2005, 01:51 PM
na2ub's Avatar
I believe my U.S. 79SC has four prongs
Doug
Doug
79 SC Targa, 22/29 torsion, ER revalved bilsteins, ER rubber bushings, carrera cooler
Old 10-17-2005, 02:02 PM
Erakad's Avatar
Sounds like heresay, but have actually gone down to the local autoparts store and bought a 4 prong relay...and it worked. Now, I've been told the non-Porsche (or Bosch, or whomever makes the oem types) cause both turn signal idicators to blink simultaneously in the cabin.......but you do get used to it. You could even disconnect one, at least you'd be right half the time.
Rob
Black 1983
911 SC Coupe
Old 10-17-2005, 03:43 PM
acapella8's Avatar
Erakad -- when you say disconnect one - what "one" are you referring to?
Also - I have seen both turn signals indicators blink simultaneously in my cabin - but have attributed it to bad wiring in the installation of a aftermarket alarm sysem. I've seen this behavior with BOTH relays -- the 3 and the 4 prong. (!?!?!?!?)
I'm awaiting my Bentley manual to shed more light on the problem.
So is it consensus that the correct relay for my 78SC Euro would be the one that has FOUR prongs, and not THREE?
[GruppeB # 978]
Old 10-17-2005, 03:56 PM
Erakad's Avatar
I've got a couple of these lying around...definetly mine is a 4 prong.
I've tried tracking down the electronics of why both lights blink when I signal either left or right...nothing made a difference. Someone on the PP board said only the oem ones (the oem turnsignal relays) blink either left or right, the off the shelf ones blink both.
When I suggested disconnecting "one", I was referring to the turnsignal lights in the cabin on the tachometer. Actually, one of mine is burned out at the moment and I've been a bit lazy replacing it. It's nice when I turn right...only one light lights up, but then of course, when I turn left only one light lights up (it just happens to be the right light )
Rob
Black 1983
911 SC Coupe
Old 10-17-2005, 06:58 PM
acapella8's Avatar
Rob - no offense, but that would drive me NUTS.
Also, would it qualify for a tech-inspection?
[GruppeB # 978]
Old 10-18-2005, 06:59 AM
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
