pmajka's Avatar
Tie rod end AAAAAAAARRRRRRRRRRRRGH
have to replace tire rod ends for DE.
Got one side done...easy
The other side, not so much....
i have just spend 3 hours trying to get it to pop. I used both a 2 and 3 prong puller...wont budge.
any tricks to get this out?
Have you ever felt suffocated while watching the Oxygen Channel?
People with excuses fail. As soon as I OK my actions with an excuse, I cease bettering myself.
88 Carrera
Old 08-19-2006, 07:42 PM
ruf-porsche's Avatar
Originally posted by pmajka
......any tricks to get this out?
Big Hammer
Old 08-19-2006, 07:44 PM
Huh Huh is offline
Can you smack the knuckle like one would do on a VW or any other car? If so take a baby sledgehammer or a BFH and smack the knuckle a with a couple of good wacks (on the section that holds the tie rod). It should just pop out. I would wait to see other suggestions but that is usually the standard way to do it rather than a puller.
'94 VW Jetta
'85 VW Scirocco
'81 911 SC coupe Euro
'67 VW Bug
Old 08-19-2006, 07:47 PM
Danny_Ocean's Avatar
Old 08-19-2006, 07:57 PM
pmajka's Avatar
What is that megafork thing called?
88 Carrera
Old 08-19-2006, 08:19 PM
one of gods prototypes
bell's Avatar
tie rod remover
Brought to you by Carl's Jr.
Old 08-19-2006, 08:41 PM
der Mond's Avatar
Let us know what works, I'm about to do the job myself.
I'm beginning to think that nothing is ever easy on a Porsche...
Peace & Thanks,
der Mond
'87 Carrera Coupe
Venetian Blue Metallic
Old 08-19-2006, 10:05 PM
Gearbox's Avatar
HEAT is your friend. Propane is ok but acetolene works faster. It's amazing how things pop apart once that red glow appears. Good luck, Allan
1971 911S, 1974 914 2.0, 1999 Boxster, 2003 Boxster, 2008 Cayman S.
www.TheLolaRegistry.com
"When you think you are in full control, you're just not going fast enough."
Old 08-19-2006, 10:31 PM
go down to parts store and buy the 2 fork set for the baby sledge.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 08-19-2006, 11:39 PM
If I understand the situation correctly..why not take the castle nut off...turn it upside down on the tie rod bolt( flush) and use an air-hammer on it? Wil pop right off and not destroy the threads. If you're not re-using the tie rod end...then the upside down nut step is not required.
- Wil
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 08-20-2006, 12:19 PM
pmajka's Avatar
FORK!
1 fork (manual, not air) and 3 whacks of large hammer. I also had let it sit with a little WD40 on it over night.
Wil, i think you may have mis understood.
88 Carrera
Old 08-20-2006, 01:15 PM
pmajka's Avatar
careful, dont whack the Disc with hammer.
88 Carrera
Old 08-20-2006, 01:17 PM
FORK!
A bigger hammer is always the correct solution to stubborn problem on a 911.
Old 08-20-2006, 01:23 PM
With your two or three jaw puller, apply some knarly tension on it, then a few good wacks with a larger hammer should shake it lose. Give it a try!
Old 08-20-2006, 01:57 PM
pmajka:
Did I really mis-understand?
I'm talking about using a reciprocating action air hammer with a blunt "tip"...
...to be used instead of a BFH..... like I suggest to "Muffin Man" in my 1-02-2005 post answer ( of 10:12 PM.. to help find it)... to "Muffin Man's" posted pics of 1-02-2005 ( 8:42 PM).
See here---> Front suspension refreshening
- Wil
.....what am I missing ???...
Wil Ferch
Old 08-20-2006, 02:01 PM
84toy's Avatar
This has never failed me......
First, rap on the side of the arm with the round part of a ball peen hammer. This moves just enough metal to open the hole a fraction by spreading the metal.
Take a piece of metal and stick it under the arm next to the tie rod so the metal (like square tubing or angle) goes from under the arm to the floor and fits firmly. Wood is too soft for this.
Now get a big brass hammer and whack the tie rod. Since nothig can flex with your metal piece going to the floor, it will pop right out.....guaranteed......
Paul S
"Those who say it cannot be done should not interrupt the people doing it"
Old 08-20-2006, 02:18 PM
I think he already got it loose with a fork and three wacks from a big hammer.
Old 08-20-2006, 03:10 PM
I don't want to derail your thread but I just pulled my tie rods today, to replace with turbo tie rods. When I pulled the boot back on the steering rack I found a cracked retainer washer and a blown bushing picture should be attached. Obviously this is the source of much of my front end problems. It looks easy enough to put back together if i could find te parts. I have spent most of the night looking at the Porsche parts catalog which does not illustrate inside the steering rack, and i have not found any rebuild kits online. People are rebuilding racks so I figure these parts have to be out there. Any ideas, I can't even get a part number. Thanks for any help and again sorry to send the thread in a different direction.
Old 08-20-2006, 05:15 PM
Picture of parts
Old 08-20-2006, 05:19 PM
Removing tie rod end
I used the pickle fork today and it was a snap to dislodge the strut side of the tie rod end. (That is with the help of a BFH) However, removing the steering rack side was more difficult. The yoke that passes through the tie rod bushing would not come off, and the Bentley manual was of no help. Luckily the other side came apart easily and I realized I could leave the yoke and bushing on and unscrew the entire assembly from the rack.
Good luck,
Hugh
Old 08-20-2006, 05:25 PM
