Venetian's Avatar
Would new speakers help?
I recently installed a new CD receiver in my 1987 Carrera. It is a Blaupunkt Indianapolis(40 watts). It was cheap and I bought it to play the odd CD. It works well but of course the sound quality isn"t great. Would upgraded speakers(same size) make any significant difference. I am not interested in installing an amp or doing any cutting.
Also can the speakers be installed without taking the door panels off?
Thanks in advance.
Old 10-18-2005, 01:14 PM
jimi_c's Avatar
Speakers will make an improvement - door speakers are a snap - just remove the door pocket to gain access. The rear shelf is a little tighter. The stock hole is very small by today's standard - Infinity makes a set that go right in the front - for the rear I had to make a riser to compensate for the bigger magnate. I'm sure there's at least one make that will drop in, just do a search. It made a huge difference for me over the stock speakers and I'm only running 45 watts a side.
Cory H
85 Carrera
Old 10-18-2005, 02:10 PM
Yes, they will help immensely. Even if you just put new speakers in the old holes. I went with MB Quart 6 1/2" speakers which required me building a plate to attach to the door and then I attached the speakers to that but there are drop in units that will fit. Do a search and you'll see the suggestions. You can search for Rod Birch at Car Audio Innovations or something like that and see what will fit.
Buck
'88 Coupe, '87 Cab,
'88 535i sold, '19 GLC 300 DD
Warren Hall, gone but not forgotten
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
