Loose Bilstein in my strut
Last winter I installed Bilstein Sports into my Boge struts.
The past 2 days I heard a noise coming from the right front suspension. Did some disassambly today and found the big nut that threads onto the strut and holds the shock in had come loose. I know I gave them some mustard (aka...extra effort) when I installed them with the trusty pipe wrench. Anyone else ever have this happen? I checked the other side and it was fine. I did use a few drops of blue locktite when I tightened it back up.
Josh '87 911 Carrera 3.2 Coupe |
Bandwidth AbUser
Yep. I used a B. F. Pipe Wrench to snug them down.
Jim R. |
Thanks Jim. Well I guess I wussed with the BF pipe wrench. We'll see if it stays put now.
Side bar: I'm really bummed I missed Shenandoah with you crazies. Looked like too much fun. I will definitely catch up with you fellas next year. ![]()
Josh, what were the noise sysmptoms of the loose nut ?
"And there's no cure like travel to help you unravel the worries of living today. when the poor brain is cracking there's nothing like packing a suitcase ..(or getting in the Porsche) and sailing away " Cole Porter, anything Goes" |
It was sorta like a knocking/banging. What I heard was the shock housing moving up and down inside the strut. Obviously it was most noticable over bumps, mostly low speed because that's when I could hear it. The nut was only a little loose, maybe allowing 1/8" play.
Thread Tools | |
Rate This Thread | |
