? on replacement front suspension pan parts
I did one of these a few weeks ago. I forgot to put in the doubling plates that go over the suspension PU. They are underneath the tank support over top of the threaded inserts where the front of the A arms bolt up. We were in a hurry so decided to leave them off for now and put them on later. This pan came from Mid America. I did not buy the pan.
I just got the front pan for my car from a different source (Restoration Design is not available right now because of there move I guess???) And these doubling panels are not included. I called the supplier and they said they dont even offer them for sale??? I looked at RDs web site and they dont have them listed either? My pan was from Vertex because its closer to me and shipping time was shorter (I had been waiting on RD for over a month and have to get my car done). My questions: Is this doubler important? Seems like it would be structurally? Has any body else done these with out this piece? Any body got a couple they can spare :-)) TIA
erik.lombard@gmail.com 1994 Lotus Esprit S4 - interesting! 84 lime green back date (LWB 911R) SOLD ![]() RSR look hot rod, based on 75' SOLD ![]() 73 911t 3.0SC Hot rod Gulf Blue - Sold. |
Here is a pic of te parts I am talking about. The doubler plate sits right above where the gas tank support is laying in the pic. (over the top of the holes where the A arm bolts up.
FYI these parts are not availble at Pelican right now. ![]()
I also got my pan from Vertex and noticed it did not have the doublers for the fwd A arm attachment bolts. I assume you mean these:
'86 Carrera Cab "The Grey White Whale" '98 Kirkham 427 Cobra(in rehab) '94 Dodge Intrepid ES(very Porsche-like) '99 F-250 SD Diesel(Cowboy Cadillac) |
Mine are way gone. You are about .....10 hours behind me in that picture :-))
Foriegn Intrigue sell both pieces for $200.00 . 1-800-800-8070 .
They have them in stock ready to go . I just bought them and installed them on a 1970 coupe . Excellent fit . Big job ! took about 10 hrs . Kurt Williams
Never drive faster than your gaurdian angel can fly. 82 SC w/965S eng and G50 6:1 hp/w ratio 72 911t 2.6 twin plug and 72' 911t 57k orig 1 own miles 65/66 912 1 owner 76k orig 01' Aston Martin DB7 V12 Vantage Coupe 6spd |
Kurt: $200.00 for just the re-inforcement peices, or for the "front pan kit"??
EW; old pic
here's where I am now:
Kurt: ELombard has the two panels, what he is looking for are the two reinforcement doublers that are not included on some replacement suspension pans.
EW: as a last resort I would fabricate (or have it done by a sheet metal shop) some doublers from .040 sheet stock. They don't have to look like the factory pieces, you could even make them out of stock channel, you don't need the flange around the periffery, that is there to facilitate spot welding, not needed if you gas or arc weld it in. Sorry I don' know how to draw on a computer to better show what I'm suggesting . Basically you want to provide a second attach point for those"T" nuts, which makes for a more stable and stronger area to bolt the suspension to. But I'm sure you know that. Good luck, and let us know how you made out.
Thanks Ted, good idea. I will just bend up a piece of stock that attaches to the T nuts and welds to the pan and the rail. wont be pretty but its not like you can see it. Its not like thats the only piece of fabrication I am going to have to meat ball :-))
EW; Yeah, it's time to use the old "EE" Degree. (Eyeball Engineering)
Thread Tools | |
Rate This Thread | |
