-   -   Tach questions (http://forums.pelicanparts.com/porsche-911-technical-forum/247046-tach-questions.html)
goose2 10-20-2005 11:48 AM
Tach questions
I'm swapping motors from a 2.4 to a 3.0 ('80 SC with CSI). The 2.4 uses a points distributor with coil and factory 3-pin CDI box. The 3.0 will use the factory breakerless distributor with coil and factory 6-pin CDI. Will my old tach work with the new set-up?
Thanks, Randy
svandamme 10-20-2005 11:50 AM
most likely yes
