915 Gearbox Pinnion Bearing Orientation
Question on the orientation of the pinnion bearing I'm planning to refit tomorrow. Because the old bearing lost its cage I'm not 100% sure of the bearing orientation. Bentley says "Install with collar of needle case facing gear set" but looking at bearing this is not clear what they're on about.
![]() I'm starting to think the collar being described is best shown in the 3rd picture. Best Regards Rob |
the lip on the bearing cage goes toward the pinion teeth.
John - basically the 3rd picture - gearbox on the left, engine on the right.
Held back fitting the bearing today - forgot to take the pinnion to work with me - twat
But looking at simular postings - the following was found!!!!!! Raised collar pointing away from pinnion:- Raised collar pointing towards pinnion:- ![]() Its my understanding the second bearing installation is correct but if there's any comments to contradict!!! |
i looked at all my R+Ps and the lip went toward the teeth, but i can't see why it wouldn't work either way. same goes for the rest of the roller bearings.
