Cigars and 911's -- Smile
Four Friday night questions (with pics) 78SC Euro...
I got my Bentley manual today, but I have 4 simple questions that I hope the pictures can help better illustrate:
What is this threaded hole near cylinder 5: Did I put on the straps correctly? I have clips on the top of the air box, and bought the better ones -- not sure if correct. This plug has always been disconnected - what is it for? I have the jack pad, a floor jack. And I bought a 911 jack on ebay for $15 -- I am still not sure on the recommended way to raise the car to change tire: Thanks in advance guys!
[GruppeB # 978] 1978 911 SC ROW (Pure Euro, no DOT or EPA work done..) 1991 Toyota MR2 Turbo (3S-GTE 4Banger Rocket) 2001 Audi - A6 Quattro 4.2L-V8 (love the growl) 2014 Honda Odyssey for the soccer-team/accessories Last edited by acapella8; 10-21-2005 at 06:55 PM.. |
#2 - the strapes should go into the curves part of the metal spring
#3 - your car was upgraded with an interrnal voltage regulator (in the alternator). So the external one including the harness(plug) is obsolete
81 SC, www.frankschroeter.com |
Wow - I don't think I understand how the straps should go. Can someone post a pic?
[GruppeB # 978] 1978 911 SC ROW (Pure Euro, no DOT or EPA work done..) 1991 Toyota MR2 Turbo (3S-GTE 4Banger Rocket) 2001 Audi - A6 Quattro 4.2L-V8 (love the growl) 2014 Honda Odyssey for the soccer-team/accessories |
The metal part should go into the rectangular cut outs in the strap.
Silver 1980SC Euro coupe |
I use the jack/jackpad to raise the car 95% of the time. The rears come up quick. You can continue to raise it enough to pull a front wheel.
But, when working on the car, you want it on jackstands: For the fronts, I raise the side of the car enough to put a 4X4 under the front wheel. Then lower the jack, and put it under the front crossmember just rear of the wheels. I think Bentley will show this location. Jackstands can go under the front A Arm mounts, and the rear torsion bars. PS-The jackpad goes in the square hole in the rocker panel just in front of the rear wheel wells. There should be a plastic cap there to cover it-it pulls straight out.
Ed Hughes 2015 981 Cayman GTS 6 speed,Racing Yellow Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4 |
Ron - thanks I get it now. Ed, yup, I was just confused as to best way to jack it up, it just wasn't clear to me.
Anyone know what the threaded hole is in pic #1?
The threaded holes, and there should be one over #4 too, are for studs. As I recall, they are for the A/C compressor mount assembly. Looks like your got stolen
, so you don't need them.
Insert Tag Line HERE.....
Number 1, is where a bolt goes to hold down the engine cover. 10mm head x 4 mm bolt x 10 mm long. Should be 3 on the each side.
You dont need the jack pad if youre using the factory jack. - But the one in the picture isnt correct for the car you have. The factory jack has a @5-6 inch "arm" sticking out horizontally that inserts into the frame the same place the jack pad goes. You raise front/rear from the same spot. The jack pad is for use with roll around jacks like the 2 ton one in the picture.
Marc |
The half scissor jack looks like a VW jack. Both of my Scirocco's had jacks very similar to your $15.00 eBay jack.
Dave
Make sure to check out my balls in the Pelican Parts Catalog! 917 inspired shift knobs. '84 Targa - Arena Red - AX #104 '07 Toyota Camry Hybrid - Yes, I'm that guy... '01 Toyota Corolla - Urban Camouflage - SOLD |
