What is it called????
The black plastic cover in the engine bay, that protects such things as the external voltage regulator, and various other relays, was altered and i feel its worthless unless it is all there. What is it called and who sells it. The car is a 77 911. Thanks for the help.
Old 10-22-2005, 09:07 PM
It's called a relay panel cover; PN 930.610.105.03 or Pelican H-610-105-03 and Pelican sells it for $18.10. In addition if the M6 x 12 winged screws are missing (2 are required) their part number is 900.029.102.02 and Pelican can order them for $1.56 each. Further the 6.4 mm washers that go with the winged screws (again 2 are required - one for each screw) have the part number 900.151.003.02 and Pelican can order them for $1.00 each.
Old 10-22-2005, 09:34 PM
