Plug for antenna post, racing
Does pelican sale such a thing or do i need to visit a local hardware store.
thanks for any help jpc
Farmers Automotive 1-800-213-6373 http://www.farmersautomotive.com 1987 928S4,1989 911 25th, 1993 RSA, 1989 944,1988 911 1968 912, 1976 911 S, 1975 914 Engine dyno![]() http://www.youtube.com/watch?v=tJKdvrX_mTI&feature=youtube_gdata_player |
I picked up a black plastic plug from Home Depot...
Brian Starr Alabama Region PCA 1983 911SC/Rebodied as 993 w 3.6 1995 911 C2 (Sold) |
Can-ya post a picture and what was the plug made for actually.
a toilet or something. thanks much jpc
I lied, it was actually from Lowe's, come to think of it. I found it on the big aisle of theirs that has all kinds of nuts/bolts/screws/ etc... I think I remember there was a whole drawer full of various size plugs. The one I needed was around 3/4 or 7/8 I think. It is made of hard black plastic.
I'd shoot you a pic, but I'm in Germany on a layover...
Thanks, no worries.
Sounds like a loooooooooooong flight. jpc
Sweet. I am looking for the same thing.
Paul 1980 911SC Targa - Sold 1972 914 - Sold |
plug
The black plastic plug for a whale tail works and it's "factory"
'68 911 2.2 "E" PMO Carbs, Electromotive Crankfire Ignition, Adjustable Spring Plates, turbo tie rods, Bilsteins, headers, MB911 muffler... "The sea merely lies in wait for the innocent but it stalks the unwary." |
What did it plug on the whale tale?
Location: member Central PA Region PCA , Home of the Hershey Swap
Rear wiper delete. regards, Steve
Steve Frequent Pelican Customer 1984 Carrera 3.2 (S. Wong Chip, B&B dual exhaust, Lightened OEM Flywheel, Centerforce Clutch, OEM 930 Rear and Front Sway Away 930 T-bars and sway bars w/OEM susp. bushings,, Turbo Tie Rods, bump steer kit, Adj. Rear Spring Plates, OEM Short Shift, H4s and "City Lights", slotted rotors, 944 Wheels, 225/50/16 and 245/40/16 Dunlop "sneakers," and more 2002 996 TT X50 (H&R Springs) 2002 WRX in WRX Blue Proud Rennlist Charter Member Support and Join Rennlist.com An Expert on absolutely nothin' more than my own opinions! 2002 WRX in WRX Blue |
That's flat though isn't it?
Need one to fit on top of the curved fenders. Where could I get that cap? Couldn't find it with our host.
I bought one from Pelican years ago.
Steve Frequent Pelican Customer 1984 Carrera 3.2 (S. Wong Chip, B&B dual exhaust, Lightened OEM Flywheel, Centerforce Clutch, OEM 930 Rear and Front Sway Away 930 T-bars and sway bars w/OEM susp. bushings,, Turbo Tie Rods, bump steer kit, Adj. Rear Spring Plates, OEM Short Shift, H4s and "City Lights", slotted rotors, 944 Wheels, 225/50/16 and 245/40/16 Dunlop "sneakers," and more 2002 996 TT X50 (H&R Springs) 2002 WRX in WRX Blue Proud Rennlist Charter Member Support and Join Rennlist.com An Expert on absolutely nothin' more than my own opinions! 2002 WRX in WRX Blue Last edited by rbcsaver; 06-04-2005 at 08:36 PM.. |
cap
I was trying to find it on the PET but have been unsucessful so far. It is so small in diameter that the curvature of the fender is not an issue
I got it from a local porsche parts dealer. I don't want to say his name on here in respect to the host. You could pM me though.
I'll ask the next time I place an order.
results for the plug search, i went to HOME depot and ACE with no success.
What does this part actually used on besides porsches. thanks jpc
I got automotive black plugs at NAPA for my bumperette delete. I ended up not using them, but they have various diameters and seem to be standard issues stuff.
Doug
Doug 79 SC Targa w/ ITBs, 2004 Cayenne Turbo |
Thanks i'll try Napa next. cheers jpc
update, i tried lowe's and they had what was needed.
I also noticed the plugs that mount in our 911 doors would work to. So either will work, cheers. jpc
can someone a measurement of that hole? I'll go to Home Depot right now and grab one.
-Vinny 1983 911SC |
when you take out the antenna ensure you put tape on your door.
open the door and loosen the antenna housing and it will slide through without taking the door off. good luck jpc
Or just let it come out the the fenderwell!
Cheers
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
