-   -   Arching across coil terminals (http://forums.pelicanparts.com/porsche-911-technical-forum/247489-arching-across-coil-terminals.html)
Scott R 10-23-2005 09:51 AM
Question, yesterday when I was putting my 80 SC back together (frequency valve, and wiring issues) I started the car up and it ran well, not great but just ok. I was about to adjust the timing however I placed my hand NEAR the coil and I received a violent shock!
I waited until nightfall as another post suggested and looked for arching, I in fact have blue sparks on both of the positive and negative coil posts, across the boot. It's actually a pretty loud snapping noise as a result.
So is this what happens when the coil fails? Or is it just a coil wire, in either case I have to order one or the other from our host, I just hate to keep throwing parts at this thing.
john walker's workshop 10-23-2005 11:06 AM
bad coil wire, bad plug connector causing the spark to take the path of least resistance (one of the coil terminals is grounded), dirt/moisture on the coil tower, could be a cracked coil snout, or internal corrosion in the snout too. and check the cap and rotor for cracks or burning.
Scott R 10-23-2005 11:18 AM
Ok, just checked. Coil wire is fried, the metal piece at the end is cracked and tarnished, as are the other plug wires as well for #5 and #3. Coil looks intact after removal, snout does not sppear to be cracked at all. Thank's for the advice on the "path of least resistance" I know nothing when it comes to electrical. I will pop over to the catalog section and order up some new wires. Thanks.
randywebb 10-23-2005 01:28 PM
also the word is arcing
if you search on arching you won't find relevant posts
check the female terminal on the coil carefully - stick an LED down there if you need to.
Scott R 10-23-2005 02:03 PM
Arching or to arch as to "cross" IIIRC, in that the spark was jumping between both termianls an the cap. When Iwas thinking "arcing" I was thinkg to ground out to somehting. But I can see what you mean.
