Senior member
Fan housing question
Hi all
I took my fan/alternator housing out last night due to a problem its wanting to move forward thus grinding into the lower pulley, the fan strap has been tightened so much its almost pulled the captive nut off, I see a hollow pin sticking out off the block but I`m wondering should there be something else in there to lock the fan housing into position? if the answer is no any ideas why this is happening. Thanks............ 1976 Carrera 3
1976 - Porsche 911 Carrera 3 1972 - VW Microbus 9 seater (low light) 1962 - VW split screen single cab |
Friend of Warren
That pin is all there is to keep the housing from shifting.
Kurt V No more Porsches, but a revolving number of motorcycles. |
MBruns for President
Sure it's not the alternator moving around in it's bushings?
Current Whip: - 2003 996 Twin Turbo - 39K miles - Lapis Blue/Grey Past: 1974 IROC (3.6) , 1987 Cabriolet (3.4) , 1990 C2 Targa, 1989 S2 |
Senior member
yeah quite sure its not the alternator causing the problem had a new one fitted 1 year ago and the fan housing was wanting to creep foward before that was replaced. slightlyf of the subject is the 11 blade fan noisier than the 5 blade i have?
