austin552's Avatar
Question Bad Oil Leak
There is a heavy oil leak up by the motor/trany. I havent got under the car yet to look for the cause yet.
Any ideas?
1974 911s
Old 10-27-2005, 09:15 AM
Work in Progress
Rich76_911s's Avatar
I think that people say that the oil breather cover back there can leak, and there is an electrical plug back there that has a tendency to leak too but I forget which one it exactly is. I think if you have waynes books he talks about both of these. But I most will say that you have to clean up the area and watch it closely to figure out exactly where the oil is comming from. I am by no means the most knowledgable person on this board and I am sure others will chime in with better information for you.
Rich
"The reason most people give up is because they look at how far they have to go, not how far they have come." -Bruce Anderson via FB
-Marine Blue '87 930
Old 10-27-2005, 09:29 AM
Work in Progress
If you have 101 projects check project 21. It covers the crankcase oil breather that has a tendency to leak, check the breather hose as well, and the Oil cooler thermostat o-ring. ANd the electrical connection that I was speaking of is the oil pressure switch. Maybe that will help. Best of luck
Rich
Old 10-27-2005, 09:32 AM
