Turbo Missfire With Higher Temps
My new EFI Turbo runs great when it's cool, but the hotter it gets it miss-fires or stumbles. This seems to happen when boost is starting to come on. This happens under heavy or light acceleration. Any ideas?
3.2EFI Manifold, Haltech, MSD, Stock Dist. Locked.
15 Cayman 93 Amethyst 964 Cab & 67 21 window VW Wife's 64 356 69 912 targa 68 911L Hot Rod |
Automotive Monomaniac
What octane gas are you using? What boost level?
2018 - Porsche 911 Carrera 7MT / 2018 - Porsche Macan 7DCT / 1993 - Cadillac Allante / 2023 - RAM TRX (on order) |
.4 Bar Boost and 91 Octane fuel. Only when engine temp increases does it miss-fire.
It could be a bunch of things. It could be an ignition miss. Bad plugs, bad wires. A bad coil. Do you have an air/fuel meter? Is it detonating when it misses? Could it be lean? Or way too rich? Does smoke come out when it misses?
Dean
Dean 911 SC turbo, 3.0L 930 motor, G50, 930 brakes, DTA EFI, 352 RWHP DynoDynamic dyno, |
The plugs are new BR8ES NGK gapped to .025. I will pick up new W3CS Bosch tuesday and gap to .35approx. Wires are new Clewett, Coil and MSD 6al New, I think it stays rich. The o2 meter reads 800-900 MV. It still only misses when it's warm.
