-   -   Help,I need this part (http://forums.pelicanparts.com/porsche-911-technical-forum/247788-help-i-need-part.html)
Dthurman 10-25-2005 03:50 AM
73' T Sunroof Coupe/Sportomatic
I am rebuilding my Trans and need this part.
It is the detent that goes inside the reverse shift fork arm.
Where can I get one ??
http://forums.pelicanparts.com/uploa...1130237327.jpg http://forums.pelicanparts.com/uploa...1130237368.jpg
Jim Sims 10-25-2005 06:42 PM
I assume you know this is a type 935 Sportomatic transmission.
In the 1972-1973 parts catalog what you call a detent was called a "locking bolt" and had the part number 925-303-149-00. This number has been superceded and is now 925-303-149-01 and the part is currently called a "trans. pin". Pelican website states this part is available for $16.06. The spring that goes with the detent/bolt/pin has part number 925-303-148-01 and Pelican shows it is available for $1.71 each. Cheers, Jim
bigchillcar 10-25-2005 06:50 PM
good work, jim.
ryan
