-   -   Still more problems - CIS? (http://forums.pelicanparts.com/porsche-911-technical-forum/247936-still-more-problems-cis.html)
Scott R 10-25-2005 05:55 PM
Well I am at wits end, and I am really just trying to get my SC into storage at this point, but here is the deal:
Replaced-
Injectors and seals (had a bent injector of all things)
Air boot between throttle body and sensor plate
Intake boots
Intake runner gaskets
Cold start valve (was inop)
Timing/frequency valve (caught fire)
WUR (no change in cold control pressure when hooked up)
Coil wire (had a crack in the metal anode at the coil side)
Cap and rotor
So now I have a new issue, I suppose... When I start the car it's hard to start, you have to crank it a while, then it backfires a bit through the air box and then catches.
It runs after this, clean and smooth as the idle stays up over 1000k for about three or for min, then the idle drops. It drops to around 950 and starts to miss-fire through out the range, I shut it down and wait about 5 min then it starts up strong again and then drops and misses.
I really want to try and figure this out, I spent a combined $700 now on three mechanics that can't get a handle on this, seems like CIS is getting rare and so are the experts.
Yellowbird RS 10-25-2005 06:00 PM
regap your points and look for an air leak
vash 10-25-2005 06:04 PM
what are the various CIS pressures? looks like someone measured the cold control press. what was it, and the ambient temp?
boyt911sc 10-25-2005 06:37 PM
CIS Trouble Shooting......
Scott,
Trouble shooting CIS problems could be both frustrating and expensive if you don't know how to check these compoments, WUR, AAV, AAR, FP, injectors, CSV. TTS, etc.
But I find the most challenging is locating a vacuum leak in a CIS system. This system is reliable and will last for a long long time if properly maintained.
Tony
bigchillcar 10-25-2005 06:39 PM
ditto with yellowbird..check points..old or dirty ones will cause backfiring. also, check timing..make sure that this is set correctly. in other words, baseline your ignition by starting with ignition basics: points set correctly, timing set correctly..then start looking for air leaks if still experiencing problems by spraying a little carb cleaner around the intake and airbox areas. good luck!
ryan
Scott R 10-25-2005 06:43 PM
Ok, well this is just great, I lost my notebook with my pressures, however I remember that cold control was 35 or so PSI and warm was 53 IIRC.
Now I went out to the grage and I have tremendous arcing between the coil posts, in fact I have a continous ZAP between the two terminals, and little blips of spark all over the braided grounds!
Has the coil failed? My multimeter stopped working the other day so I can't yet check resistance on the coil, but why would it do this?
EDIT: It's an 80 so no points, I wish at did at this point, (no pun intended)
Also on the airbox leaks it was removed and checked a few weeks ago, it appeared sound on all sides.
Tex3 10-25-2005 06:46 PM
ryan
wow , assuming that Scott R's is a 80sc . I didnt know that they had points in them :confused: i guess you learn somthing new everyday
ianc 10-25-2005 06:47 PM
Scott, I'll take a crack.
You say that the car is hard to start. Is this a cold or warm start condition or both? Approximately how many secs of cranking does it take to start and what is the ambient temperature?
Have you measured the warm and cold control pressures and system pressures? What were they and what was the temp they were measured at? What is the part # on your WUR?
After replacing all this gear, have you had the mixture checked on an EGA, or tried playing with it?
You describe a couple of problems that to me would point to different causes. The hard cold start is usually unrelated to poor cold running; a poor warm start can also have different causes. The fact that the car runs OK upon finally initially starting but then drops after a bit leads me to believe that the WUR is still not operating correctly, as enrichment from the WUR would be responsible for ensuring a smooth transition from the cold to warm regimes.
Any change if the O2 sensor is disconnected? Do you have a popoff valve and is it seating properly on its gasket?
ianc
Scott R 10-25-2005 07:17 PM
Both cold and warm are hard starts, about 60 seconds of cranking on cold, it catches right away on warm but dies until you hold the gas for a while
I'll get the part number when it gets light out again, however I have two, one is the original (came with the care) and the other is an adjustable from an 82. I will recheck pressures in the AM when it's cold again. However I think it was 35~37 cold and 53~55 hot last time.
Yes it costs me $20 per trip and I had it done last week, it was set to 3.1 IIRC.
I will check the pressures again in the AM and post them.
Will check the O2 sensor in the AM as well, I am pretty sure it's plugged in however you never know. I will check the pop off valve as well, it was pretty well secured when we checked the air box, but it never hurts to check again.
ianc
ianc 10-25-2005 07:26 PM
So which is it: warm starts are hard, or it catches right away when warm? If cold start is your only trouble, then I would immediately look at your cold start valve installation. Are the wires put on the thermotime switch correctly? Switch is in the LH chain cover and it does make a difference which way they're installed. Try reversing them and see if that makes a difference.
If you have an adjustable WUR, then you should be able to set your control pressures very accurately if you have a pressure gauge and know what temp your checking at. The ambient temp is very important. Let me know your pressures and temp and I'll look them up in the factory workshop manual to see if you're in spec. Making sure control pressures are in spec is the absolute first step in diagnosing a problem like this.
ianc
Scott R 10-25-2005 07:41 PM
Will do on the pressures, and it's cold starts crank for sixty seconds then catch, idle is low then idles up and runs well until warm.
Hot starts are about 30~60 seconds cranking and I can't keep it running at all unless I have my foot on the gas.
As far as the thermotime wires are concerned I think they only fit one direction, red IIRC is on top and the white is on the bottom.
ianc 10-25-2005 07:50 PM
OK, so it sounds like you're having both cold and hot start problems. Hot starts problems have different causes than cold start. Most likely culprits for hot start are the fuel pump check valve and the fuel accumulator.
Cold start issues are usually the cold start valve. The wires on the thermotime switch can be put on either way. I have an 80 also, and the wires are red\black and yellow. The switch is at the far left of the top of the driver's side chain cover.
ianc
LFogelson 10-25-2005 08:23 PM
Maybe your CDI is bad. I was having issues of my car running very irregular and backfiring until it completely stopped running. Switched to an MSD ignition and this solved my problem.
Scott R 10-25-2005 08:28 PM
You know it would not suprise me, I don't appear to have consistant spark when I disconnect a plug wire and watch it. Anyway to test a CDI?
LFogelson 10-26-2005 08:27 AM
Easiest way is to swap with a known working one.... if you can find someone to lend you one.
Scott R 10-26-2005 09:24 AM
I am going to borrow one from my mechanic today, he has a few spares so he says.
Jim Williams 10-26-2005 02:30 PM
Scott,
Reference your remark early in this tread about the arcing between coil posts: This is a symptom of no ground at the coil. You might double check this. Trouble shooting CIS is a real problem when the spark is not reliable.
You might find some help with CIS by looking here:
<http://members.rennlist.com/jimwms/CIS/CIShome.html>
Scott R 10-26-2005 05:52 PM
Originally posted by Jim Williams
Scott,
OK thanks, does the coil go right to ground from one of the two posts? I will pull the wiring diagrams up and try and make sense of it.
Also I brought home a loaner CDI unit tonight, and it was the wrong one, I have a six pin and I brought home a three pin.
Anyway here is an update on other things, I went out just now and started it up, it stumbled a bit then picked up right away to about 1500RPM, then as it warmed up over say three minuets the idle droppped down to 950 and then it started to arc and miss again. It does not arc until after the warmup part is done.
I will try and borrow a six pin CDI tomorrow, but I am still very stumped, and I had no time to check fuel pressures.
tdatk 10-26-2005 06:33 PM
Scott,
I see you replaced the coil wire. Good, I believe that the rest of your plug wires are shot. If they are arching to the braided sleeve, they are probly cracked. Most likely all the spark thats supposed to go to your plugs is shorting to the braids. Try new wires.
Tim
Scott R 10-26-2005 07:32 PM
Ok, plug wires it is. Now do I go with braided? Or not?
ianc 10-26-2005 07:35 PM
No on the braided. This was a misguided factory attempt to fix the blown airbox problem which they later solved by mounting a fuel runner for the CSV in the airbox itself.
Just get the plain Bosch or Berus, depending on your preference,
ianc
tdatk 10-26-2005 07:49 PM
ianc
That will do just fine. Be careful to route them exactly as they came off and ensure they are seated good in the cap and on the spark plugs, you don't want another issue.
Tim
Jesset100 10-26-2005 07:56 PM
Change your spark plugs too
Scott R 10-26-2005 09:53 PM
Plugs are new, I installed them we I dropped the motor last month, would you change them again? I will if you guys think I should it.
