defcon65's Avatar
engine cleaning
What's the best way to clean a 911 engine? ( I'm not taking it out). Aside from a battery disconnect and covering electronics components, what are the recommended cleaners/methods? It's not real filthy, just the typical oil and dirt film.
Thanks,
Joe
Old 10-25-2005, 09:09 PM
Targa, Panamera Turbo
M.D. Holloway's Avatar
Choose a solvent with some butyl in it - cuts oil and grime really well. Be careful around the plastic and rubber components - some solvents will dry them out and make'm crack.
Michael D. Holloway
https://5thorderindustry.com/
Old 10-25-2005, 09:16 PM
scottb's Avatar
Engine cleaning article.
Engine cleaning article, part 2.
1984 Targa
Old 10-25-2005, 09:18 PM
FrayAdjacent911's Avatar
Send a message via AIM to FrayAdjacent911
I have it under good advisement that Gunk Engine Brite works good... so I picked up a couple cans at my FLAP... Now that I'll be getting a '69 Targa, and transplanting my engine into it, I'll clean the engine after I extract it from my '70 coupe.
Matt J.
69 911T Targa - "Stinky"
2001 Boxster "Stahlgewehr"
Old 10-25-2005, 09:49 PM
randywebb's Avatar
if 'typical' and 'not real dirty' means to you what it means to me... I'd just leave it running and spray with Simple Green or similar and the flush off immediately. Don't leave it on.
Be sure to get the bottom and don't let the water go into the storm drains.
Then go for a drive.
When you get back the engine will be dry. Check for any areas that still have a film on them and spot clean with a rag & brake cleaner.
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 10-25-2005, 10:03 PM
GOT TURBO..
MobileWrks's Avatar
Get the engine HOT, goto a dollar or 99c store, there is some stuff called "awsome" the as seen on tv spray... WOW does a great job...
Old 10-26-2005, 08:14 PM
