-   -   Frosted Fuchs (RSRstronomy) (http://forums.pelicanparts.com/porsche-911-technical-forum/248089-frosted-fuchs-rsrstronomy.html)
M. Hendrix 10-26-2005 05:24 PM
Who is Harvey? Is he the only guy that does perfect RSR wheels?
M
Vipergrün 10-26-2005 07:43 PM
Probably Harvey Wiedman (sp). If you want the RS(R) finish, you can also try Al Reed in the LA area. I had a quote of $700.00 to have my 7x9 Fuchs finished like that from Al. I should note that the price was not direct from Al, and included some labor and transportation charges. You would have to call to get an accurate quote.
randywebb 10-26-2005 10:03 PM
Yes - only Harvey does perfect wheels - go to the 911S bbs and search there - you'll find a thread that compares both people.
If by 'perfect' you mean 'fine' or 'ok' then Al Reed will be a bit cheaper and faster.
M. Hendrix 10-26-2005 11:14 PM
Thanks guys, I searched here, and saw people saying Harvey, alot.
M
Jack Olsen 10-27-2005 12:27 AM
Has any wheel refinisher come up with a way to do an RSR look that doesn't require special care and feeding? I love the look, but in my particular circumstances, I'm less in need of 'correctness' than I am of a finish being pretty much maintenance free. My wheels get changed at least once a month, and the RSR finish wheels I've seen so far are sensitive to both brake dust and fingerprints.
dean 10-27-2005 06:01 AM
I also like the RSR look. I like the polished look too. I can't decide for my car. If I went with the RSR look, I would bead blast the paddles. Then I read that the POR15 Co. has a clear product that you can brush on Alu. It might be worth a try. I think I am going polished though.
http://www.por15.com/product.asp?productid=246
Dean
jtkkz 10-27-2005 10:14 AM
RSR finish are the pain to upkeep, one of my 911 has the RSR finish.
My other car I had my brother powder coat it to look similar to RSR finish but much easier to upkeep. Unfortunately he will not do the black painted middle section, I had to paint that myself.
pic attached of the powder coated wheel
http://forums.pelicanparts.com/uploa...1130433277.jpg
