-   -   nippondenso rebuild post (http://forums.pelicanparts.com/porsche-911-technical-forum/248461-nippondenso-rebuild-post.html)
kepperly 10-28-2005 11:13 PM
I remember a post long ago by Rod Walter the pca lincoln trail region on nippondenso a/c compressors. I have a spare for my 87 carrera and want to try to freshen it up over the winter. does any one have the part #'s for a service/ rebuild. I have a source for denso/ nippondeso parts at dealer cost and would share my IN.
thanks keith epperly
87 slant nose turbo look carrrera cabrioet
Tigerrat 10-29-2005 08:28 AM
Keith - I think that same article is in the tech info center here. Don't know the part numbers but there is a shaft seal kit, and an o-ring/valve reed kit. I got mine from ackits by giving the compressor model number. Ken
imcarthur 10-29-2005 09:39 AM
Just to divert a bit . . .
Mine's leaking at the shaft & I plan to rebuild this winter. Is it safe to assume there is no refrigerent left? Can I just unbolt & walk away or does that kill baby seals or something?
Ian
kepperly 10-29-2005 09:52 AM
To double check just take a small screw drive and depress the schrader valve like you were letting to much air out of a tire. If its got freon left you will know. Then if it does maybe someone will evacuate it for you and save the freon for when its time to refill.
Keith Epperly
imcarthur 10-29-2005 10:02 AM
http://forums.pelicanparts.com/uploa...1130605143.jpg
Thanks Keith
The pressure valve that's circled? Or the suction valve?
Ian
imcarthur 10-29-2005 11:03 AM
Keith
Answered my own question. Yes it still has refrigerent.
For seals, I found this:
Polar Bear Inc
and this:
acsource.com
Ian
scottb 10-29-2005 11:10 AM
Rebuilding a Nippondenso compressor.
kepperly 10-29-2005 11:51 AM
Thanks to everyone that chimed in on this thread, I just ordered
the gasket set and shaft seals from AC Source.Com for $28.04
including freight.
Thanks again
Keith Epperly
imcarthur 10-29-2005 12:07 PM
Keith
Which seals did you order? Since I'm going to be doing the same . . .
These?
http://forums.pelicanparts.com/uploa...1130612797.jpg
http://forums.pelicanparts.com/uploa...1130612816.jpg
kepperly 10-29-2005 09:21 PM
I ORDERED BOTH SETS ITS SO CHEAP, ONE OF THOSE WHILE YOUR IN THERE DEALS AND I WON'T FEEL BAD IF I JUST THROW SOME AWAY!!
KEITH EPPERLY 87 SLANT NOSE TURBO LOOK CARRERA CABRIOLET
GUYS WAIT UNTIL I CAN POST THE 68 EL CAMINO PHOTOS, I KNOW ITS NOT A PORSCHE BUT IT IS A JOY THAT I WAS ABLE TO DO A FRAME OFF IN LESS THAT 2YEARS. NOW I WANT TO MAKE MY 87 3.2 INTO A 3.4 AND ANYONE HAVEING PARTS EMAIL ME.
ryanmt 10-30-2005 04:04 PM
I bought the rebuild kit this summer. The rebuild was fairly simple. I also decided to replace all the o-rings in the system with the green nitrile(?). This was to be certain that my system was leak free. Replacing these orings was worth it as many of them looked bad. Might consider that as my o-rings were 20 years old.
