gas leak, front of car?
Guys,
Filled up near the house after a long drive, I discovered a big puddle of gas dripping from the front of the car after I pulled into the garage. Driver side dripping from what looks like a hose (with hose clamps) coming out of the fender well just above the wheel. Is that some kind of overfill outlet for the gas tank? It gets worse after I start the car. Can't get under there, too tight, floor jack on loan to a friend. Its never there when you need it. Something to worry about? Oh it is an 88 930. Thanks Jeff |
Most likely a leak from your vapor recovery system. Could be a loose hose or a cracked tank. You will need to pull the wheel to look.
