Problem replacing light switch
I have removed the light switch pn 911.613.029.01 and replacing with 911.613.029.03 which according to PET is the correct number for years 74-89. Two differences, K terminal has been relabed N and terminal 58 has been added.
Well, didn't notice the extra terminal and screwed up transfering the wires from switch to switch. Two things I want to verify. I guess 58 stays blank. And I have a red lead with white stripe coming from the blinker stalk joined together with a solid red lead. What terminal does it go to? Thanks. |
Walt;
Assuming you have a US car, here's what the factory diagram shows: 30 2.5 re & 1.5 re/wh 75 1.5 re/wh 56 1.5 wh/bk L .5 gr/bk & 1.0 gr/bk R 1.0 gr/re & 1.0 gr/re K .5 gr & .5 bk/bl 57 .5 wh/gn 58a .5 bk/bl & 1.0 bk/bl & 1.0 bk/re where the colors are : bk black bl blue re red gr gray gn green wh white and the numbers ndicate the metric wire size. Hope this helps, JR |
...and to answer your last question, it shows the red wire from terminal 30 on the headlight switch going to the terminal 30 of the ignition switch and the red/white wire on terminal 30 of the headlight switch going to terminal 30 on the turn signal switch.
JR |
| All times are GMT -8. The time now is 06:03 AM. |
