Help with dead cylinder
Guys, after everything that has been replaved on my 80 CIS I now have a dead cylinder. #2 refuses to fire at all, it's not a miss, it's dead and I checked or replaced the following:
1. New plug wires 2. New rotor 3. New cap 4. changed plugs for #2 cylinder 5. Swapped injectors 6. Did compression check (around 129 to 130 psi) on #2 Interesting enough is that fact that it will idle perfectly even though you can hear drop out in the exhaust pipe, and it has no power, and when I unplug that wire, nothing happens, when I unplug another I hear that cylider drop. I'm stumped, what should I try next?
2021 Model Y 2005 Cayenne Turbo 2012 Panamera 4S 1980 911 SC 1999 996 Cab |
inlet manifold gasket? Check for air leak on No2
1984 3.2 Carrera Impact Bumpers on track: http://www.youtube.com/watch?v=C4qbFNkdD2o |
burnt out injector?
The intake runner gaskets are new as well as the rubber boots, but I will check again. I did notice that the injector was pretty easy to remove however, and I did spray carb cleaner all around the injector sleeve with no bubbles, or change.
Scott,
You changed the injectors and the problem stayed with #2 cylinder, right? With good compression and fuel that leaves ignition. I would pull the #2 wire, connect it to another plug, restart the engine and verify a spark. If you get spark, remove and either dry off the sparkplug or replace it. No spark, replace the ignition wire.
DOUG '76 911S 2.7, webers, solex cams, JE pistons, '74 exhaust, 23 & 28 torsion bars, 930 calipers & rotors, Hoosiers on 8's & 9's. '85 911 Carrera, stock, just painted, Orient Red |
I did in fact do that pulled the plug and fired it grounding it against the motor, plenty of spark was present, I did that test with two different wires, and two different plugs.
check for a broken intake rocker on that cyl.
Tim in Sac |
sorry, missed the fact that you swapped injectors on my previous post
, you might want to check the wiring to the injector if all else fails. Those wires live in a pretty unfriendly environment.
Ok, had to work all last night (that's what being an IT employee get's ya) and I started late on this thing today. So this needs to go down in the bonehead hall of fame if we have one. I had the firing order for # and #3 backwards on the distributor. I found this out after I reomed all of the valve covers of course.
Anyway wanted to drop everyone a "thanks." I now have a perfect idle, great power and smooth running.
Happens all the time. Glad you found it.
PS mskar, AFIK, there are no wires to the injectors on an 80 SC. I think you're thinking of a 3.2. |
Too bad for me now it's getting cold, and race season is over.
Good for you Scot, Congrats.
