-   -   1974 engine setup in newer SC (http://forums.pelicanparts.com/porsche-911-technical-forum/248880-1974-engine-setup-newer-sc.html)
Porsche_911s 10-31-2005 01:41 PM
I am in the middle of my restore and have started seeing rollers that are in better condition than my 1974. Mechanically my 74 is done. But body & paint wise I am about to get started.
Question: What would I need to do to get my 74 2.7 setup working & legal in a 76 or newer car?
Edited to add useful info:
1974 coupe weight ~ 2370 lbs
1978 targa weight ~ 2700 lbs
'74 CIS 2.7 ~ 150 HP (with carbs & "S" CAM ~ 170 HP)
'78 CIS 3.0 ~ 180 HP
2.7 engine weight ~ 401 lbs
Modification needed:
- 6 plug CDI to 3 plug CDI
- 14 PIN engine connector rewired correctly
- Speedometer changed out & cable ran ('74 915)
- Tach changed out
- temp gauge changed out (recommended upgrade on '78 anyway)
- Going to carbs, CIS mods not needed, fuel system removed for carb fuel system
jmz 10-31-2005 02:37 PM
putting an 81 based engine in my '74 was a piece of cake. I suppose the opposite is true.
Porsche_911s 10-31-2005 06:31 PM
I think the Houston smog test will probably kill me.
jmz 10-31-2005 07:40 PM
I guess it depends on how clean your engine runs.
ianc 10-31-2005 09:19 PM
Put a 2.7 in an SC? Forget it. Dump the motor and the whole car and just get something newer if that's the way you want to go,
ianc
Porsche_911s 11-01-2005 06:11 AM
hhhmmmm... get a divorse because I dumped lot of cash in a 2.7 motor before joining this site.... OR, keep the motor & the hot wife and just get a 74 or 75 roller... I think I will just look for the 74 ot 75 roller. The lack of response makes me think it's more trouble than it's worth.
jmz 11-01-2005 06:24 AM
OK, here's my advice:
IF your LIme Green '74 is really a P.O.S. then don't waste your time. IF it is a rust free car then go after it by yourself just don't pay somebody to do the body work and you will be $$OK that is if you just want a fun car.
If this is some way a financial investment for you then you have other problems. You will almost NEVER make any money on these cars. I suppose the salvage title would make it that much harder though. If the salvage title bothers you AND you 2.7 is fully sorted and running well just find any old roller with a clean title. A pre-74 will prove to be the best investment (again hard to make money on these cars) but any roller will do. You've got everything you need on the '74 to transfer to whatever roller you end up with to make that 2.7 fit and function. Go and buy the factory manuals if you need to they are really helpful.
JZ
s2per 11-01-2005 07:07 AM
You mentioned that the smog test would kill you on an '81. I'd go with the newest roller that would work with your area's smog laws. Definitely get a '76 or later and be sure to swap your shorter-geared '74 915 trans into the newer car. An early SC roller with limited options and your freshened drivetrain would still be a fun car.
ianc 11-01-2005 09:24 AM
I think putting it in a mid year would be fine if you can find a decent one. The earlier post about it being an investment is correct; you won't make any money on the motor. But, if you chose to sell it, you might get enough out of it to finance a new project.
I just don't think a 2.7 in an SC or Carrera is the way to go. Something earlier and lighter,
ianc
Rich76_911s 11-01-2005 10:19 AM
I do not completely understand. If you want to put it into a 76 or 77 that would be the correct engine, 78 and up you would have an underpowered SC. I recently saw a post from a Texan whos car is now smog exempt because it is more than 25 years old. Is this only a law out in the country and not in Houston? Do you have family that lives outside of the city where you could register the car to avoid city requirements? I am not sure about the laws in Texas, but the exhaust system on a 74 is not as clean as the 75 -77 mid years. I think you could swap out the hear exchangers from a 75 - 77 fairly easily. But I feel like there might be more than just the heat exchangers. It probably wouldn't be that hard to locate used parts to get you to a 75 and up middy as a lot of people backdate to the 74 style exhaust. I guess it really depends on the year car that you would end up with and what the laws are where you have the car registered. Can you register it as a collector car, antique ect ect? Some states do not require emissions testing on cars that go under 5000 miles a year too. Look up the texas DMV and see what your options are.
Rich
Porsche_911s 11-01-2005 12:40 PM
I was WRONG and mis informed! Just checked and any car over 24 years old DOES NOT need the smog test. Thanks for correcting me!!!!
I am not looking at this as an investment by any means but at the same time I am at a point where I can make a body switch and get a clean title. I want the car for cruising and coastal driving. After the switch I can sell mine off cheap as a track car.
Hhhmmmm so I should probably take a look at the weight of my 74 -vs- the weight of a newer car.
Thanks guys!
Porsche_911s 11-01-2005 01:13 PM
Do these weights sound correct??
1974 911s 2380 LBS
1978 911sc 2470 LBS
1981 911sc 2558 LBS
I plan on flaring out the 74 & running 16x6 & 16x8. That will probably increase my weight some.
Also, could anyone tell me the weight difference a 2.7 setup and the 3.0 setup?
Thanks!
ianc 11-01-2005 01:26 PM
Not sure about those weights. I think SC's are weighing in closer to 27-2800 lbs. Lot of variables there though, AC, coupe or targa, fuel load, etc. If you do a search here, you'll probably find more info. For two similarly equipped motors, both CIS equipped etc., I think the weight diff between a 2.7 and a 3.0 is negligible,
ianc
Porsche_911s 11-01-2005 01:34 PM
Those were kerb weights.
I'll see what type of rollers come across the classfied section.
jmz 11-01-2005 04:35 PM
The aluminum 3.0 engines do weigh more than the magnesium 2.7 engines. By how much, I am not sure.
pjv911 11-01-2005 05:27 PM
I disagree with the above post which states that with a 2.7 the sc would be underpowered . Power to the seat of the pants would be indistingquishable (wow thats a long word).
Furthermore a fresh 2.7 would be more powerful than a worn 3.0 anyday . And 40lbs lighter too . I see no problems with this guys intensions . And its a direct fit . Swap the flywheel and bolt it in .
Kurt Williams
ianc 11-01-2005 06:44 PM
2.7 ~ 150 HP; 3.0 ~ 180 HP. Not a good idea if you're ever thinking of selling the car again either.
ianc
pjv911 11-01-2005 07:03 PM
150hp yes but thats if his 2.7 had the thermal reacters bolted back on (doughtful) .
175hp with 74` type exhaust . Factory hp for 74 was 175hp .
5hp/40lbs you decide which is right and which is an elusion .
Kurt Williams
Porsche_911s 11-01-2005 07:29 PM
I'm running strait headers into Supertrapps... I think I have 7 rings on the Trapps. Had 9 but it was very very loud.
ianc 11-01-2005 10:59 PM
According to the factory workshop manuals for the 74 model year, the claims were 143/167 SAE HP for the 2.7/2.7 S Carrera with 8 and 8.5:1 comp ratios respectively. Neither will equal the torque of a 3.0, and the SC is heavier than a middie. As I said before, what buyer will look twice at an SC or Carrera with a 2.7?
ianc
pjv911 11-02-2005 06:49 PM
True about resale . But if he keeps the car he will still enjoy it just as much with a nicely tuned 2.7 . But I do understand your point.
Kurt Williams
Porsche_911s 11-02-2005 07:09 PM
I guess I have to get a SC now just to see what the 74 2.7 setup would be like. And, I could set an example of what you could do or what you should never do.
Instead of being "Munson'd" in the middle of no where... You guys will refer to 911's as being "Stephen'd"! hahaha
jmz 11-02-2005 07:35 PM
I wouldn't necessarily set out to find an SC roller, just a clean title and no rust. If you are running super trapps on your 2.7 it sounds like you don't have problem with the whole hot-rod/bastard thing anyway.
...I've got to ask; Where exactly do you plan on doing this "coastal driving" planning on cruising up and down the sea-wall??? We don't exactly live near Hwy 1.
JZ
Porsche_911s 11-02-2005 07:41 PM
I'm looking for a 74 to 82, not just an SC. There are some roads towards Victoria & towards Corpus. It was more of an expression. We just love getting out in driving the country side.
Yeah, I don't care if it's a bastard. I started this thread asking what all was involved and it ended up being "if I should". But, I do appriciate the advice and comments. Good or bad. It makes me look at things from different angels.
Rich76_911s 11-02-2005 08:28 PM
One thing to note while looking for a roller is that sometime in 1976 the started to galvanize the bodies. So ideally you might want to look for a 77 and up to be sure that you have a galvanized body. If you plan on keeping the car it might be something that you should consider. Houston can get pretty humid, right?
Anyway good luck with the project. I did not mean to get a debate about the 3.0 vs 2.7 going. I just knew that one has less hp's than the other, that's all I meant by underpowered.
