Elephant Racing Packages
Just been over to have a look at anything new at the Elephant Racing site, and found that Chuck now has a great suspension package finder application here
I like the look of Street / Track 1, and wondered if anyone had experience of actually buying as a package from Chuck. Post your pictures and impressions of this new service - takes the hard work out of selecting the components to buy. Example, I see he includes Hollow Sway Bars but not Monoballs in Street / Track 1, whereas to the un-initiated (i.e. me) I might have selected the reverse. Appreciate parts are also available here at Pelican, and not in any way trying to push trade one way or the other.
Ian Highfield 1992 964 C2 Manual with RS Suspension etc. 1973 911T Narrow body Hot Rod with 2.7 Carrera engine and loads of period modsl - SOLD 1986 Carrera Coupe Sport with Stainless Silencer and SW Chip (256 fwbhp) - SOLD |
I bought full set of suspension bearings and uprated torsion bars from Chuck. Top quality parts and good bloke to deal with.
Parts fitted perfectly - no problems at all. Last edited by rob justice; 11-01-2005 at 10:49 AM.. |
coolcavaracing.com
I used the tool yesterday to help select the parts I should get, and then placed the order with Pelican as I was after some other parts that ER did not have at the same time
I used the Street/Track 1 to select the following parts for my 911:.- Low-Friction Control Arm Mount Kit - Elephant Racing .- Bump Steer Kit .- 22.5mm Front Hollow Torsion Bar .- Elephant Racing, Front Poly Bronze Suspension Bushings
Pål (Paul) - The Norwegian lost in Finland... 1978 911SC 3.6 | 2001 Boxster S Racing Car | 1966 912 based 911 RSR replica racing car (for sale!) come and follow the Porsche Sports Cup racing fun and me at www.facebook.com/coolcavaracing
22 mm front torsionbar! That will be a stiff ride. What will you use in the rear?
Are you going to track the car or just street?
Magnus 911 Silver Targa -77, 3.2 -84 with custom ITBs and EFI. 911T Coupe -69, 3.6, G50, "RSR", track day. 924 -79 Rat Rod EFI/Turbo 375whp@1.85bar. 931 -79 under total restoration. |
coolcavaracing.com
I will do the back later, but was going to go to 28 when I get to it. The car will be 99% street - but weekend fun only
I read the tech article (http://www.pelicanparts.com/techarticles/911_torsion_bars/911_torsion_bars.htm) and ER tool to help me with the selection - do you think I have gone to stiff??
Kroggers,
I think 22.5 hollow is like a 23mm solid, but cannot be sure. From what I have read, that is pretty stiff for a street car. Chuck previously suggested 22/29 and I see lots of cars on here with that setup. Others run 23/31 but that seems stiff - also depends on the types of raod you drive on, as uneven road surface will make a stiff car 'skip' from side to side through bumpy corners etc. If it isn't too late, drop Chuck an e-mail direct for advise - he is very helpful.
I have no experience, but I think it could be a little stiff for 99% street, you don´t want to get tired of the car...
I will go to 21/27 maybe 21/28, but I´m also thinking stock(19)/27. Mine will be mostly street but also Auto-X (Porsche Club Slalom).
coolcavaracing.com
Thank you Ian and Magnus, I have already sent a quick email to Pelican to ask if it is to late to change my order from 22 to 21mm bars... If not, then I will fit the 22mm bars and see how it feels..
If its to late, you could always resale them i Sweden if you don´t like them. Big torsionbars are at short supply....
coolcavaracing.com
Good thinking Magnus
