Porsche Less Member
k9handler's Avatar
Send a message via Yahoo to k9handler
Has anyone cut the tunnel?
I am going to be doing another engine drop and the most difficult part is getting the shift rod to clear the opening at the back of the tunnel.
This got me thinking, if I cut a 4"x 2" section out of the bottom the engine and tranny could then be lowerd straight down and out of the car. A small plate could be made to cover the opening when everything is in and secure.
Is this a key area of the tub that sould not be modded? My thought is that since the tranny support/mounting plate is right behind this area that it would not degrade the strength of the tub.
Your thoughts?
H.D. Smith
2009 Dodge Ram 1500
1978 Mercedes 450SL
2014 Specialized Allez
Old 11-01-2005, 12:37 PM
sounds like an old scca racer trick we've seen. besides being careful with the cables, fuel lines, and electrical- we don't see a problem. Especially if you make a strong frame to support your cover. That would restore and strength along the seam
1970 914-6 street"evil cockaroach"
1970 911 Spyder
1970 911S Conda
1973 911S Glacier Blue
Old 11-01-2005, 12:45 PM
randywebb's Avatar
Structural integrity - it is part of the backbone of the car.
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
it'll be an issue if you ever sell it.
206 637 4071
Old 11-01-2005, 12:51 PM
PRO Motorsports
Tyson Schmidt's Avatar
Your car is a '75, so it should have the little eyebrows that connect the top of the center tunnel to the torsion tube. That should take care of any strength issues.
But I think I agree with John Walker on the issues with resale value. Most people frown upon drilled and sawzalled cars.
R-Gruppe member #382
'69 911E coupe' 2.7E MFI (retired 911-Spec racer)
'72 911T Targa
2004 GT3
Old 11-01-2005, 01:05 PM
dtw dtw is offline
GAFB
Fuel lines, cables, wiring harness all very tightly packed in there. I'd not risk it. Getting the shift rod to clear the tunnel has never been a problem for me...maybe you need taller jackstands?
'72 911T MFI VW Silver Metallic
'84 911 M491 non-sunroof Slate Blue
'01 996tt Lapis Blue
Old 11-01-2005, 01:23 PM
Tim K's Avatar
This is taken from the www.gunnarracing.com site
http://www.gunnarracing.com/project/Martini/MartiniRSR-1119.htm
While sort of unrelated, this was for a " special magnesium transmission".
Tim K
Old 11-01-2005, 02:08 PM
devalued member
juanbenae's Avatar
this is group B we are talking about here. the scars from such carnage are worn like badges of honor in that circle.
75S slick-lid webered, early n spicy 3.oL hotrod wanna be
07.5 2500HD GM Diesel 4x/93 tuff-gong 4.oL YJ Wrangler
08 DRZ400SM+FCR Mikuni
78SC PRC Spec911(sold 12/15) https://www.youtube.com/watch?v=f7I6HCCKrVQ
Old 11-01-2005, 03:12 PM
Yellowbird RS's Avatar
X/A
Old 11-01-2005, 03:30 PM
911SCfanatic's Avatar
I think that is why the front of my rebuilt '72 915 transmission has an aluminum cover supporting the shift rod. Looking at the oblong hole for the shift rod into the tunnel on my car, my guess is the PO got the shift rod hung up in the tunnel and cracked the mag cover.
Bill G.
'68 911 Ossi Blue coupe
Old 11-01-2005, 05:20 PM
len911's Avatar
Search for posts on "tunnel" I have posted pictures of what the interior of the tunnel looks like sometime within the last year. Lou
'76 911 "Moneypenny" daily driver
'74 911 "JLo" IROC DE Car
'03 CRV, '02 Jeep Grand Cherokee
'03 Holiday Rambler Admiral SE, 30ft, 8.1l, 340HP, 455Ft#
http://www.nicotra4.hpshare.net/BasketCaseMotorsports/
Old 11-01-2005, 05:42 PM
Grady Clay's Avatar
I tried unsucessfully to find the thread where someone posted images of a complete tunnel removed from the pan. Does anyone have that link?
Best,
Grady
ANSWER PRICE LIST (as seen in someone's shop)
Answers - - - - - - - - - - - - - - - - $0.75
Answers (requiring thought) - - - - $1.25
Answers (correct) - - - - - - - - - - $12.50
Old 11-01-2005, 08:36 PM
here they are
X/A
Old 11-01-2005, 08:57 PM
Porsche Less Member
k9handler's Avatar
thank you all for the responses. I am not looking to cut out that much...just the width of the circle opening down and then a few inches into the tunnel.
Maybe you guys at TRE have some other ideas, when I pull the 3.6 it's a big PITA to get the engine/tranny back enough in the car to clear the shift rod. The fan housing hits the back of the car and at that point the shift rod is still about 1" inside the tunnel. So to get the engine out it takes a sissor lift, tranny jack, jack stands, and two or three guys assisting.
It seems that I have had to drop the engine/tranny at least once a year so why not make it a little easier. =o)
H.D. Smith
2009 Dodge Ram 1500
1978 Mercedes 450SL
Old 11-01-2005, 09:44 PM
wot wot is offline
wot's Avatar
HI
When I drop the engine from my SC I always remove the fan-housing first, takes some time but it gives me enough room to get the shift rod out and in again.
Erik
82 SC 3,6 73 RS Look
Old 11-02-2005, 12:04 AM
Porsche Less Member
k9handler's Avatar
Thanks Erik...that was one thing I was considering to do the drop this time. Still think a notch in the tunnel would make things easier down the line in future drops.
H.D. Smith
2009 Dodge Ram 1500
1978 Mercedes 450SL
Old 11-03-2005, 08:52 AM
rw7810's Avatar
K9handler - I like your idea. Please post your efforts here.
Bob Williams
70' 911T
Old 11-03-2005, 06:55 PM
rob justice's Avatar
I bought myself a Pallet Truck, with the back of the car jacked up to clear the engine, the angles are perfect and the engine just slots right in. I bought mine for 32 and it was the easist engine fit I've ever carried out.
Old 11-03-2005, 10:00 PM
rw7810's Avatar
HD - did you ever do this??
Bob Williams
70' 911T
Old 08-11-2006, 06:29 AM
MBruns for President
JeremyD's Avatar
Rob, what muffler is that?
Old 08-11-2006, 06:49 AM
