-   -   need help (http://forums.pelicanparts.com/porsche-911-technical-forum/249075-need-help.html)
sylvester 11-01-2005 03:07 PM
need help
i have a 1979 porsche 911 coupe and the problem is i smell gas inside the car, its comming from the engine compartment i look and didnt see any gas dripping anywhere any clues where it can be comming from thank you for the help guys.
Tom '74 911 11-01-2005 03:29 PM
Check this link:
http://forums.pelicanparts.com/showthread.php?s=&threadid=244041&highlight=fuel+l eak
I dealt w/a fuel leak recently and it was here and easy to fix. A good way to check - turn the key, but don't start the car, so the fuel pump starts running, pressurizing the line. Then start crawling around underneath your car, looking for the leak! I could see mine from w/in the driver side rear wheel well.
Good luck,
Tom
