Send a message via AIM to GTI0125
First drive
After picking up my '75 Carrera about a month ago, I got it back from the shop yesterday and took the first real drive. I am hooked!!! It still needs a lot of work but the fealing of that flat 6 sitting right behind me was amazing.
the car needed a good tune up after sitting for over 5 years but after cleaning the gas tank and getting a new fuel filter, new distributer cap, points, and other random stuff ( missing fuzes), it fired right up.
The idle is good and after about 5 mins on the road the smoking stopped and the car ran great. That was till i ran out of gas. It seems that the gas guage is broken, and i just about made it to the gas station. Glad that the car is not that heavy.
I had been doubting my purchase but after this first drive the restoration is back on.
Old 11-02-2005, 07:55 AM
a.k.a. G-man
Geronimo '74's Avatar
Go for it!
Have a blast.
Enjoy the SHIp out off it.
i really have to brush up on my DIY skills.
Old 11-02-2005, 08:05 AM
All the smoke did worry me but I knew there was probably about a liter of oil on the manifolds. You could see me comming!!! Looked like something from a Jame Bond movie or something. I did find i have a oil leak on the driver side some where, but it seems very slow.
A beautiful day in western MD and just me and my new 911. It was a good day
Old 11-02-2005, 08:10 AM
}{arlequin's Avatar
GTI,
since you're "in the area", make sure you stop by www.dorkiphus.com
lots of locals and plenty of help/support/fun runs
dave
1973,5
Old 11-02-2005, 09:03 AM
Registered Cruiser
jorian's Avatar
This thread is useless without pics....
87' Carmine Red Carrera - Keeper
82' Silver SC - Sold 79' Gran Prix White SC - Sold
05' Black C2S - Daily driver
I have never really completely understood anything.
pictures can be found here new to me 911
Old 11-02-2005, 09:06 AM
GTI,
Once, when I over-filled the oil tank, I had smoke coming out of the exhaust as if I were spraying for mosquitoes. The oil expands under heat, it backs into the air chamber, gets ingested with the incoming fuel-air mixtures, and smokes like the devil. Everyone thinks you've blown an engine, but you know better.
Sure can be worrisome, though!!!
Andras
1983 911SC The Chocolate Kiss
1998 Audi A6 Quattro (Family Car)
2002 Audi TT Roadster (Wifey's Car)
1992 Mazda Miata (Daughter's Car)
1991 Honda VFR750F Interceptor
1982 Honda VF750S Sabre
Old 11-02-2005, 09:17 AM
I checked the oil after the engine was nice a hot and the level was a little high.
Will the extra oil just burn off or do i need to drain and refill with the right amount?
What are the size of the gas tanks? When i filled up after running out yesterday it only took 10 gallons, is this right?
Old 11-02-2005, 09:21 AM
Hi GTI,
1. If there is just a little extra oil , it will burn off, but with the aforementioned smoke. The difficulty is to remove just a little. There are two places you can drain, the sump and the tank. The sump holds about 3 quarts, the tank about 8 quarts (more or less). So it appears that you might want to drain the sump, not the tank. But do this only if you truly have too much oil. And then refill, using the dip stick as a guide, not your gauge on the dash.
2. The gas tank should have about 21 gallon capacity. Though my current ride (looks like yours) has the 21 quarts, my earlier 1974 (also looked like yours!!!!!) had a little less, but far more than 10 gallons. Something's wrong with your filler tube, I think. I can't imagine that you would have 10 gallons of water logging the tank.
3. To truly see what's wrong, you might want to let your car get low on gas, and then open the large drain on the bottom of the tank (you'll need a reversed spark-plug socket to open her up, since it is a 21mm socket (plus or minus), and the spark plug socket, reversed, fits. But realize that any "residue" gas will spill out in a hurry, so plan ahead. Then you can check to see what else comes out of that tank. Ohterwise, there is a problem with your filler tube, and might be blocking any more gas from entering the tank.
Andras
Old 11-02-2005, 09:33 AM
vash's Avatar
sweet ride! smoking deal!
congrats. hey, i fried a fuel pump letting it suck dry. be careful.
poof! gone
Old 11-02-2005, 09:34 AM
21 gallon tank? Yea i got a problem, take to crawl back under there and take another fuel bath.
Towards the end of the drive yesterday the smoking had stopped and the oil level was at a more normal level.
Old 11-02-2005, 09:40 AM
Then you really do have to investigate why you're able to fill only 10 gallons. Most Porsche have large fuel tanks to allow you long range.
Also note that I DID SAY TO DRAW DOWN YOUR FUEL before you open the lower drain
Please read the entire post, not just the first and last words.
Andras
Old 11-02-2005, 09:42 AM
its not like i was going to take the plug out with 10 gallons of fuel in the tank
Old 11-02-2005, 09:52 AM
Registered Cruiser
jorian's Avatar
Trailer & car for 5K?! Good candidate for a track weapon. Looks like a great deal. Cool color scheme. Brown is in. You might say its' the new black.
Old 11-02-2005, 09:58 AM
vash's Avatar
now just hold on one second. dont be opening that drainplug. do it the safe way. take out the five nuts that hold the fuel level sender in. slide it out, and take a careful peek into the hole. dont use a candle for illumination . get a flashlight. i dont know why you cant get to the last 11 gallons of fuel. the pickup line is at the bottom. as a bonus, you get to turn your sender over to see if the float is moving freely.
poof! gone
Old 11-02-2005, 10:00 AM
Sorry GTI, I didn't mean to imply anything, except that I was responding to your statement ".....and take another fuel bath".
But you do have a problem, and the only thing I can think of is that your filler tube is somehow to blame. All Porsche tanks are more than 10 gallons, and even if it's been bashed in on the bottom, there would still be more than a 10 gallon capacity.
Check inside the front trunk, where you can see the filler tube going into the tank. You could also remove the round plate which is the top of the fuel gauge sensor, and pull that out without emptying your tank. Just be careful with the fumes resulting from that removal.
Andras
Old 11-02-2005, 10:01 AM
Thanks for the tips
Old 11-02-2005, 10:04 AM
FrayAdjacent911's Avatar
Send a message via AIM to FrayAdjacent911
Matt J.
69 911T Targa - "Stinky"
2001 Boxster "Stahlgewehr"
Old 11-02-2005, 12:16 PM
Okay you guys, sheeeeeesh!!
Here is a picture of my tank, before the restoration, (turn your head sideways - this should be rotated 90 degrees).
Note the large diameter filler tube, the smaller diameter vent, and the top plate of the fuel guage sensor.
If yours are bent or damaged, or missing, that might account to why you are getting only 10 gallons into your tank.
Is there a tiger in your tank ? wink, wink.
Andras
Old 11-02-2005, 12:25 PM
With all the other things i am finding out with this car I would not be surprised.
The PO(my uncle) is just the kind of person to put a false floor fuel tank in.
I'll be checking on my fuel situation over the weekend, thanks for the tips and info
Old 11-02-2005, 12:31 PM
