Going to attemp rear torsion bar removal, will this work . .
I am mentally preparing myself for the torsion bar to be seized in the spring plate. I've been reading all kinds of advice on how to "undo" this problem.
My question is can you use, say a puller for a steering wheel or harmonic balancer (for v8's) and put some long bolts so they go past the sping plate surface and somehow rig a piece of metal that would go from one bolt to the other, but hehind the plate, knock a hole in the endcap and pull the hold end off that way?
Just a question, Im just getting a mental inventory of fixes.
here's a pic:
1986 944 Turbo - Guards Red
Old 11-03-2005, 11:44 AM
greglepore's Avatar
Why not just get a puller with jaws rather than bolts?
Greg Lepore
85 Targa
05 ST3s (unfinished business)
Old 11-03-2005, 11:55 AM
450knotOffice's Avatar
I think it would work.
Old 11-03-2005, 12:03 PM
Yeah, that might work too. I guess it would work, as long as the jaws didn't slip!
Old 11-03-2005, 12:09 PM
I would rather be driving
jpnovak's Avatar
you don't need a puller. Just drill a hole in the end cap and drive out the torsion bar with a drift and BFH. I just inserted a block of wood between the body and spring plate and swung for the fences. Came right out after my other methods of heat and clamps failed.
YMMV
Old 11-03-2005, 12:20 PM
Breeang's Avatar
Never underestimate the power of brute strength and a big hammer.Sometimes I could have the job finished if only I hadn't stopped to think about it !
1957 KR 200 Messerschmitt Bubble Car 3 wheeler-my first rear engined air cooled German car,alas long gone!.
1977 911S 2.7 to spend money on
2006 Tundra for acting grownup
Old 11-03-2005, 12:38 PM
DP935 member
kycarguy 935's Avatar
A hydraulic press would work also if you have access to one. I once had a real stuck torsion bar in a 70T and the big hammers and metal rod wouldnt remove it. The paint was really nice so I didnt take any extra chances with the hammer and finally used a press. Good luck.
Porsche Slantnose M505 M506 group on Facebook.
https://www.facebook.com/groups/719995181372494/
Old 11-03-2005, 12:44 PM
YMMV
how does this work if the other end of the TB is stuck too. when you hit the end the TB will have nowhere to go. Or do I not get the method? do you pry AND hit?
Old 11-03-2005, 01:38 PM
greglepore's Avatar
Actually, I'd be surprised if your bars on an '86 are stuck that hard-but then again, you live near the Gulf.
Greg Lepore
85 Targa
Old 11-03-2005, 01:46 PM
Yes, I live in the gulf, but most the the cars life was in the Northwest.
Old 11-03-2005, 01:51 PM
Kantry Member
oldE's Avatar
Yes, a small puller with jaws works well.
Les
Best
Les
Old 11-03-2005, 02:27 PM
ianc's Avatar
Good point. What do you do if the inboard end is stuck?
ianc
BMW 135i. Nice. Fast. But no 911...
"I will tell you there is a big difference between driving money and driving blood, sweat and tears." - PorscheGuy79
Old 11-03-2005, 02:58 PM
greglepore's Avatar
If the inboard end is stuck you unstick it towards the center of the car, once its unstuck it should come right back thru the splines to come out.
Greg Lepore
85 Targa
Old 11-03-2005, 03:20 PM
