clutch adjustment
Reading the tech article and Wayne's 101 book clutch adjustment seems straight forward. But can't find a set of 1.2 and 1.0 feeler gauges. Where do I go?
Moke 81 ________ 1981 SC |
Any old set of feeler gauges are fine. You may just have to add up blades until you have a 1.2 and 1.0.
Registered abUser
I have accumulated several sets of feeler guages over the years. They are all in thousandths, I convert to mm.
When I had a real job, we had a huge conversion chart that must of been 5'x3'. It listed metric, decimal, standard, fractional conversion and drill/tap size chart. Does anyone know where I could buy one now? We used to get them free from our machine tool vendor. |
Senior Member
Not rocket science. You adjust it so that the bit arm starts pushing the little arm before the helper spring goes "over the top."
Man of Carbon Fiber (stronger than steel) Mocha 1978 911SC. "Coco" |
1.0 mm = 0.039"
1.2mm = 0.047" Maybe this will help.
Thank you, HFR_Racer '87 930, 3.3 liter, K27 hybrid, Kokeln IC, Andial, B&B, Borla, 17" Supercups. |
Thank you all for your help.
