Can this targa latch be repaired?
As seen in the pic, the "center twisting receiving pin" that the handle goes into is completely broken. Can a new pin be installed?
Tru6 Restoration & Design |
if you can deal with something not quite original, you can cut the female end off a 1/4 drive extension, grind it down a bit to fit as low as possible and braze it in place. then grind one of the keys to a square. maybe even use a tiny 1/4 drive socket and braze it in.
if you have the original piece that broke off, you might try fitting a thin wall sleeve around the original pieces and silver solder it all together.
https://www.instagram.com/johnwalker8704 8009 103rd pl ne Marysville Wa 98270 206 637 4071 Last edited by john walker's workshop; 11-08-2005 at 04:00 PM.. |
Thanks John, I'll try fabbing up your suggestion on the extension. Nice idea.
