What will starting fluid do? It might make it run for a bit, but if there is a problem, cold start or otherwise, it's not going to fix it.
ianc
BMW 135i. Nice. Fast. But no 911... "I will tell you there is a big difference between driving money and driving blood, sweat and tears." - PorscheGuy79 |
Cold start valve is only used when you first go to start the engine. Afterward, the thermotime switch cuts out the cold start valve. If the engine tries to start with the starting fluid, after the first time the engine run, the cold start valve is no longer required to start the engine. Last edited by ruf-porsche; 11-08-2005 at 07:45 AM.. |
ianc
Somatic Negative Optimist
It doesn't crank? Or it turns over but doesn't start? If it doen't crank, your battery is suspect along with the relevant wiring to the starter. A black relay will work just for a testing the pump. Pull one of the injectors while lifting the air sensor plate. Pick an injector that's already loose, spray a little WD-40 on the O-ring, then use two open-end wrenches to pray STRAIGHT up. There should be a fine spray with the pump running. Careful; have a fire ext. handy. Let us know what you find.
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD! 1995 seafoam-green 993 C2, LSD, Sport seats. ![]() Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
How long can the engine continue running if there's no fuel being delivered but was able to start using starting fluid? Or, would the engine even start at all?
![]() Quote:
ianc
Anyone want to comment on the use of starting fluid with a CIS airbox? For the record I always put the toilet seat down. My wife taught me that! |
This thread has become very confusing. These should be the troubleshooting
steps: 1. The engine must crank over at a good RPM. 2. The coil wire to the distributor must produce a spark of about 25mm to the engine case. 3. The fuel pump must run when the sensor plate is moved. 4. The system pressure must be at least 60-70 psi. The control pressure (cold) should be about 25 to 30 psi. 5. The spark plugs must NOT be saturated with fuel, i.e. from cranking without a spark. This is a common no-start issue on 911SCs. 6. Check the cap for moisture (shielded caps a problem). Then check the rotor. Then check that the spark at the plug is strong. Don't assume that a good coil spark is a good cylinder spark. If all of the above are O.K., then check the mechanical elements of the engine, e.g. compression, or ignition/valve timing.
Have Fun Loren Systems Consulting Automotive Electronics '88 911 3.2 '04 GSXR1000 '01 Ducati 996 '03 BMW BCR - Gone Last edited by Lorenfb; 11-08-2005 at 09:22 AM.. |
Just because you have power going to the dizzy doesn't mean that you have a spark. |
Designer King
Have you checked your battery output? You say your car sat for a week. Sometimes w/ these cars, you may have enough power to run the fuel pump but not enough to actually start the engine.
Paul Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9 Never leave well enough alone |
2. I can check this. 3. This is happening. 4. Pressures were checked recently, car was running and starting perfectly until this abrupt malfunction. 5. I doubt that this is the problem. The sudden onset would not so indicate. 6. Not the problem. A "mechanical elements" problem would be surprising, given that the car went from running and starting perfectly to not starting simply by sitting in the garage for 6 days. The type of problems you suggest would likely show prior symptoms. I have owned 8 911's and have had a myriad of problems. This one is strange, unless it is an ignition problem, and it is getting at least some spark. |
Please let us know what does fix your SC. This thread will help another Pelican in the future.
"2. The coil wire to the distributor must produce a spark of about 25mm
to the engine case." Sounds like this hasn't been fully ckecked, right? This is a very key test. Again, these engines flood easily with weak sparks, so check & clean all the plugs. Also, if the plugs are dry then maybe it's a fuel problem.
Have Fun Loren Systems Consulting Automotive Electronics '88 911 3.2 '04 GSXR1000 '01 Ducati 996 '03 BMW BCR - Gone |
Thanks for the reality check, Loren.
twopoorsche: Testlight? DO NOT use a test light on the distributor to determine proper function; the CDI system is not the conventional ignition from olden days. A test light may be good for an old Ford, but you can harm your CDI module with this crude approach. Test light on the Bosch CDI ranks along with testing the Alternator by disconnecting the battery with the engine running; still runs? then the alternator is o.k. (But now I wonder why the diodes burned out?) Some people never made the mental conversion from Generator to Alternator. Anyway, if you have had that many Porsches, Loren's advise on how to troubleshoot a non-start should be familiar. Do it systematically through elimination instead of guessing and jumping all over getting nowhere. When an engine gives problems, it's either fuel, or ignition (electrical), or mechanical. You mention "Not cranking" but you also "It just turns over"??????? Try Loren's advise and let us know what you find. And, get a Bentley Repair Manual; it's a great help.
"Not sure I agree with you. The key is to not ground the test light. It will still light up if not gounded. Why would it harm a diode? If you ground the test light, then you would be correct."
1. Gunter is correct about NOT using a testlight on a CDI coil. The low resistance of the testlight may cause an execessively high current for the internal SCR device damaging the CDI unit. 2. The testlight will NOT light if it's not ground. The pulse from the CDI is less than 200us. Even if grounded, you'll never see a flash. So the test will be a waste.
Have Fun Loren Systems Consulting Automotive Electronics '88 911 3.2 '04 GSXR1000 '01 Ducati 996 '03 BMW BCR - Gone Last edited by Lorenfb; 11-10-2005 at 07:34 PM.. |
If you want to know how to troubleshoot/test your CDI, do a search here. Burning out diodes is referring to the alternator, not the CDI. There are still people who believe that disconnecting the battery while the engine is running is the way to see if the alternator/VR works. I am just mentioning it as one of those practices that don't seem to die out; like a testlight on the coil with a CDI system. Anyway, follow the steps suggested by Loren and let us know what you find.
Update
Pulled a plug. I am gettng visible spark. Plug was dry when I pulled it, and the engine had been turned over for 30 seconds or so before pulling the plug.
Reinserted plug, and used a liberal amount of starting fluid. White smoke from tailpipe, but NO indication of starting. |
