Clutch cable adjustment
I assume the transmission needs to be in neutral to adjust the cable?
I'm having issues sometimes going into reverse. All other gears work fine during shifting. I've raised the car and at the moment with the car in neutral there is no gap between the adjustment screw and the lever is this normal? I have replaced all the shifter bushings and installed a aftermarket coupler
Old 09-26-2023, 01:24 PM
rs6er's Avatar
Send a message via AIM to rs6er Send a message via Skype™ to rs6er
Are you sure you have the coupler adjusted right?
John
Original owner '81 911SC blackmetallic coupe. Terbatrol, SSI, M+K Gen 4, SC+ cams, A/C delete, console delete, heater backdate, 7 & 8 x 16 Fuchs with polished rims, Turbo tie rods, tensioner update, Rennline engine mount bar, Mainely Custom sump plate, new top-end, corner balance.
Old 09-26-2023, 01:25 PM
I think so, I marked the original position of it when I removed the old one. Leaving the car in 3rd gear position and putting it back. Would that effect the position of the clutch cable?
Old 09-26-2023, 01:33 PM
rs6er's Avatar
There is a lockout tab to keep you from going from 5th to reverse. If your coupler is adjusted wrong, you may not be clearing or actuating this tab when you go from neutral to reverse. Was it working before you put the new coupler in?
John
Old 09-26-2023, 01:37 PM
walt's Avatar
You should have a 1.2 mm gap between the adjustment screw and lever with the cable disconnected and 1mm after connecting the cable. Also check you have 25mm +/- .5mm of travel at the cable end when the clutch is fully depressed.
Walt
82SC 3.0
81SC 3.6
Old 09-26-2023, 01:45 PM
There's no gap at all at this moment. I'll do the adjustment to put it into spec.
Old 09-26-2023, 02:22 PM
Should there be a 1mm gap as it sits now without any adjustment?
Old 09-26-2023, 02:23 PM
If you only replaced the coupler and didn't touch the clutch cable...the coupler is likely your problem.
Old 09-26-2023, 05:28 PM
Did the adjustment but I think I screwed it up now.
Old 09-26-2023, 05:31 PM
rs6er's Avatar
Repetition deleted.
John
Old 09-26-2023, 05:52 PM
rs6er's Avatar
Originally Posted by rs6er View Post
This is my 915. 1st picture is in 5th gear.
John
Old 09-26-2023, 05:53 PM
rs6er's Avatar
3rd gear
John
Old 09-26-2023, 05:55 PM
I managed to do the adjustment but now I have a bit of play on the pedal, feels like the pedal travels about 1" before feeling the clutch engaging. When I let go of the pedal it feels like the spring let's go at that 1" play. Need more adjusting?
Old 09-27-2023, 09:44 AM
Banned
The clutch return spring on the pedal assembly may have given up on life. The geometry of it is such that it assists when you're pushing in the clutch, and also pushes the pedal up at rest. Mine broke a few years back and had that same slack at the top until I replaced it.
Refer to this post which shows the spring during installation. https://forums.pelicanparts.com/porsche-911-technical-forum/159061-dreaded-clutch-pedal-return-spring-2.html#post5473958
Old 09-27-2023, 11:14 AM
walt's Avatar
1" play seems a bit much, mine is usually around 1/2" after adjustment. Recheck your 1 mm gap. My omega spring gave out after 40 years also, if you're in there probably not a bad time to just replace it.
Walt
82SC 3.0
81SC 3.6
Old 09-27-2023, 12:28 PM
I didn't have that play prior to doing the adjustment
Old 09-27-2023, 01:40 PM
Make sure the gap is there with cable disconnected, when cable is connected there is no gap.
Old 09-27-2023, 01:59 PM
PCA Member since 1988
As long as the clutch fully disengages when the pedal is most of the way down (but before it's all the way down), you're okay. You can get around to replacing the clutch pedal spring or other parts "whenever."
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 09-27-2023, 03:34 PM
rs6er's Avatar
Does it need adjustment if it only disengages all the way down?
John
Old 09-27-2023, 03:46 PM
My clutch engages about an inch off the floor but it is completely disengaged when the pedal is all the way down. If yours is like that it’s fine. If it’s barely disengaged with the pedal against the stop it needs. Adjustment.
'80 SC Targa
Avondale, Chicago, IL
Old 09-27-2023, 05:37 PM
