-   -   Brake fluid overflow? (http://forums.pelicanparts.com/porsche-911-technical-forum/250334-brake-fluid-overflow.html)
cashflyer 11-09-2005 06:21 AM
Brake fluid backflow?
Somebody please explain this before I have to start selling the excess fluid on eBay.
A while back, when I checked the fluid before a race, I found that the top of the resevoir had some errant fluid around the cap. I sopped it up with a shop towel and checked the resevoir - which was full.
This past weekend, I again checked the fluid before an event, and found more fluid around the top. But the resevoir is still full. Where is the extra fluid coming from and WHY??!!
http://forums.pelicanparts.com/uploa...1131546041.jpg
EDIT: Changed title for accuracy
dweymer 11-09-2005 07:20 AM
When you release the brakes, the system pushes fluid back into the resevoir. I don't think the resevoir should be filled to the top, take a little out and see if that fixes it.
jluetjen 11-09-2005 07:31 AM
I wouldn't fill it past the step on the outside of the resevoir.
Chilling in VT 11-09-2005 09:08 AM
Wouldn't/shouldn't the excess fluid pass out the overflow tube and not out the top? Is your overflow tube plugged? Anyone?
Joe
dweymer 11-09-2005 09:29 AM
Yes it should, could be blocked.
Bill Verburg 11-09-2005 12:21 PM
It's very common for fluid to collect there, the cause of the overflow is 3 fold; initial overfilling, expansion due to heat and pad knockback
The level will drop as the pads wear, you can also use a syringe to remove a litle fluid.
BBKs used w/ stock reservoirs exacerbate the issue, because they push so much more fluid.
Quicksilver 11-09-2005 12:28 PM
If the fluid has risen a very noticable amount then it means you are boiling the fluid but you should notice the pedal turning to mush.
Otherwise: what Bill said...
