early mirrors on SC
hey all, i noticed my 993 aero drivers mirror is loose on my car. its a real pain to tighten up. i've got the door panels off because i'm putting in RS panels to complete my interior (i will post pics once its finished). however, i really don't like the 993 mirrors on my car. i will likely backdate the car anyhow, so do i just put some early mirrors on now? i mean, will they just simply drop in and fit?
if so...anyone got a pair? (driver & passenger).
Cheers
Kyle.
Old 11-09-2005, 06:09 AM
armandodiaz's Avatar
I can't answer your question but I am looking for aero mirrors for my track car, keep me posted.
Armando Diaz
85 911 Carrera - Track car
01 996 Carrera - For Sale http://forums.pelicanparts.com/showthread.php?s=&threadid=327823&highlight=996
87 944na - Old Daily Driver, now 944 CUP
03 Chevy Avalanche- Support Vehicle
70 Olds 442 W30 Conv- Gone but not forgotten
http://www.diazracing.com
adiaz@diazracing.com
Old 11-09-2005, 06:42 AM
jmz jmz is online now
jmz's Avatar
not sure how "early" your talking about.
but, I'll bet that the mounting holes are in the wrong place. You may have to weld patches and fill the old holes and drill new ones.
JZ
-Jay '74 Mexico Blue 911 3.0 EFI (Fast and Loud)
'70 914/6 Race Car (Faster and Louder)
'71 73RSR tribute vintage race car 3.0
'68 SWB 911T "RENNRAT" 2.8 twin plug/915 gearbox
'81 Magenta IROC clone in progress 3.6 varioram/G50
Old 11-09-2005, 06:50 AM
the 993 mirrors have a 3 prong mounting points. looks like 2 prongs simply drop in the holes in the door, and the 3rd has a allen head attached to it...when tightened, it pinches the plate inside the door and holds in in place. sorry, i should've taken pics. hope this makes sense.
Old 11-09-2005, 06:54 AM
jmz's Avatar
pretty sure the early mirrors are mounted further forward than the later ones. I am talking anything pre-75 when I say early. ( i.e. non-flag mirrors.)
Old 11-09-2005, 07:00 AM
Dan in Pasadena's Avatar
JZ
I can confirm this. I just had the flag mirrors removed from my '76 and I backdated to the rectangular stainless mirrors. You've got to have the large square hole for the flag mirror welded shut with a plate, ground smooth and then new small holes drilled to correspond to the early mirrors. Hope this helps.
Dan in Pasadena
'76 911S Sahara Beige/Cork
Old 11-09-2005, 07:04 AM
oh darn it....that is exactly what i didn't want to hear. thanks for the info. Dan, i'm guessing you had to have the door repainted after the welding? or did the base of the old mirror cover up the plate/welds?
maybe i should just install a set of flag mirrors in the meantime........hmmm........
Old 11-09-2005, 07:19 AM
jmz's Avatar
no such luck, you will have to paint.
Old 11-09-2005, 07:34 AM
JMZ is correct, you've got to paint.
My car is undergoing a complete repaint, so the mod didn't matter.
By the way, you've got to drill two 1/2" holes on the inside of the door -hard to describe where - far forward, all the way to the top above the door panel. This gives you access to tighten the bolt heads against the inside of the exterior sheet metal. If you look closely you will see two little dimples in the places you have to drill. They are left over from the early days, the door metal hasn't changed.
The early mirrors use a round head bolt with an internal hex.
Dan in Pasadena
Old 11-09-2005, 08:34 AM
thanks very much for all the info. I think i will put this idea on the shelf for the time being. my cars paint isn't great, but not in need of an immediate respray. maybe i'll luck out and the stock flag-style mirrors will fit back on w/o having to repaint. stock flags would be better than the aeros i have on now.
thanks again.
Kyle.
Old 11-09-2005, 08:37 AM
Less brakes, more gas!
euro911sc's Avatar
If you want to give up your Aero's let me know. We may be able to work out a deal. If you want my power flags We can throw that in too
-Michael
Michael
'82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah
'13 Cayenne GTS
Old 11-18-2005, 12:46 PM
Will do Micheal, you are second in line...fyi
Old 11-18-2005, 12:48 PM
