Me like track days
Craig 930 RS's Avatar
Exclamation ** GT3 style front oil cooling for 74-89 911s! **
*****SEE BELOW*****
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ -
"930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe
Movie: 930 on the dyno
Old 05-11-2005, 08:42 AM
Me like track days
BELOW >>>>>>
Old 05-11-2005, 08:44 AM
I can see 'em just fine
Old 05-11-2005, 08:49 AM
Mike Bonkalski's Avatar
Try losing the space after ...uploads5/
That may work.
1971 Targa RS - Sold
1964 BMW 1800Ti
1969 BMW 2002
Old 05-11-2005, 08:50 AM
I think your filenames are too long, and are getting munged by either the PHP parser or the browser.
Old 05-11-2005, 08:51 AM
Me like track days
Excellent! Thanks Thom!
When we went to Daytona for the 24hr, a pre-race radiator replacement got the mind a - thinking...took a few pictures in the garage.
Look at the top pic at how a GT3 has its radiator positioned.
Why couldn't a 74-89 with a center mount oil cooler function the same way? Top center vents at a low pressure area in conjunction with the high pressure radiator inlet? Check.
Couldn't we add those to the 'smile' filler piece?
Let's see what we have.
Cooler mounted close to the pan. No shrouding.
Air flows right past the center cooler. A Carrera cooler in the fender with 2 fans + this essentially non-functioning cooler + a modified 3.6 = 250+ temps at the track in 75 degree ambient temps. Not good. Improvements needed.
Time to get to work.
So, what did I do here?
Hole saw the holes in the center of the front bumper. May clean up to open the entire center section which creates a long rectangle.
Bumped out the cooler an inch from the pan.
Added sheet aluminum shrouding at the bottom on the bumper - a piece as long as the cooler and 2 inches wide, screwed to the bottom of the bumper and painted black. Easy to do. Also added a piece inside the upper C-section of the bumper to seal the top.
1 pieces on each side, and the cooler is boxed in.
Cut slots in the smile/steel inner smile piece and painted to match.
The result? Air flow *through* the cooler and a majority goes UP through the slots and over the hood.
Functional results? Identical conditions last year (72 degrees) resulted in 250+ temps. This year........215, tops. Cost? Minimal, if you already have a center mount cooler.
A HUGE difference!
Old 05-11-2005, 08:55 AM
KobaltBlau's Avatar
Craig, I Realize you no longer have this car but how about some more info:
1. where did you have this cooler installed before you did it this way?
2. what cooler is this? Dimensions?
Andy
Old 11-10-2005, 02:13 PM
Limbo
Slider79SC's Avatar
Here is the way my buddy did it on his 930 with a wicked 3.6 twin for go juice.
Big ol built Duramax
Durango R/T 19’ Current Custom project
V8 M3 08’ Built and spoiled
Old 11-10-2005, 02:38 PM
KobaltBlau's Avatar
Aha, I've seen dave's car but not looked at it in detail. do you know what cooler he used or any more photos?
Andy
Old 11-10-2005, 02:41 PM
Me like track days
2. what cooler is this? Dimensions?[B]
Only had one fender cooler before we installed the front.
Dimensions....I don't recall (car sold) but it was a pretty standard Setrab size as I recall.
Old 11-10-2005, 03:16 PM
