wcc wcc is offline
wcc's Avatar
Oil siphon
Has anyone used a siphon to pump out the oil? Since it comes out so fast and there is A LOT of it I thought about pumping out most of it and draining the rest of it. I'd leave about 1-2 quarts in to flush out what's left when I pull the plug.
Has anyone done this and is it a good idea?
Bill
997.2
Old 11-09-2005, 12:17 PM
Friend of Warren
Easier just to drain it.
Kurt V
Old 11-09-2005, 12:21 PM
wcc wcc is offline
wcc's Avatar
The last time I drained it I had a friend that had access to a lift and one of those big drums on wheels with a commercial grade funnel on it. It was huge. When that oil came out it almost flowed over the top of the funnel.
So now it is my turn and I don't have access to those great tools. I have about a 5 quart oil catcher. I plan on getting a bigger one. I just don't want to make the news for an oil spill. That is my major concern.
If draining it is still the best way to go what are you guys using to catch such a large amount of fluid? I plan on leaving my car on the ground.
Bill
997.2
Old 11-09-2005, 12:32 PM
Friend of Warren
The search button is your friend.
Kurt V
Old 11-09-2005, 01:01 PM
mschuep's Avatar
I use a big plastic kitty litter pan, wal-mart < 5 bucks. Check to be sure it can hold enough fluid with simple volume math.
this might help with conversions
http://www.digitaldutch.com/unitconverter/
-Matt
1985 Targa
Old 11-09-2005, 01:20 PM
GOT TURBO..
MobileWrks's Avatar
Also, Walmart does have a small pump that i also carry with me. Pumps out just enough, small and or large.
Old 11-09-2005, 01:22 PM
I use a large plastic concrete mixing pan from Home Depot. Works perfect for all my vehicles. Holds tons of oil and is only about 6 inches tall.
Randy
'87 911 Targa
'17 Macan GTS
Old 11-09-2005, 02:18 PM
Targa, Panamera Turbo
M.D. Holloway's Avatar
not sure you have to. Autozone has a oil change pan that holds 3+ gallons. If you drain the crank then empty then drain the sump you have plenty of room.
Michael D. Holloway
https://5thorderindustry.com/
Old 11-09-2005, 02:31 PM
wcc wcc is offline
wcc's Avatar
I'll check out that pan from Autozone. That one sounds like a winner to me.
Thanks!!!
Bill
997.2
Old 11-09-2005, 03:49 PM
Southern Class & Sass
Dixie's Avatar
I use a big 15 gallon bucket for the tank, and a 5 gallon Blitz oil drain pan for the sump.
Dixie
Bradenton, FL
2013 Camaro ZL1
Old 11-09-2005, 03:52 PM
Total Oil Volume........
WCC,
The total oil volume in your engine is just about 3 gallons (12 quarts). So a 5-gallon container is more than sufficient for an oil change job. You need atleast 1 three-gallon drain pan to drain the oil tank; empty it and then drain the engine oil.
TD
Old 11-09-2005, 05:50 PM
I have an oil siphon....It Sucks. Sorry for the pun. Mine if the Griot unit and it works reasonablly well. This method is often used for inboard boats where it can be dificult to drain the oil. It is ok but draining is better.
Don
72T Coupe - SOLD :-(
Old 11-11-2005, 08:46 AM
This one might sound a little strange, but when I changed my oil and didn't have a suitably large container I used a large plastic bag. It obviously fits easily under the car, having a flexible shape, and once full you drain it into old oil cans by cutting off one corner of the bag with scissors. Try it and see.
Ian
Old 11-11-2005, 10:59 AM
petrolblue83911's Avatar
Ian,
You're brave!-hot oil into a plastic bag!-better have been a strong ass bag!
-Just Kidding, did that really work?
-I drive up on ramps, and place a 5 gallon bucket underneath.
-the autozone large capac. catch is ok, but the problem can be that the oil comes out a bit faster than it can drain into the containers sump, so you end up watching as it rises and rises, and eventually overflows the side!
Old 11-11-2005, 11:31 AM
na2ub's Avatar
I got an open-top big a$$ container from my local auto store. Don't forget that even if you have a big container, if the drain hole in the middle is small in diameter, the oil cannot get into it fast enough and you will be dumping large amounts of kitty litter on the garage floor.
Doug
Doug
79 SC Targa w/ ITBs, 2004 Cayenne Turbo
Old 11-11-2005, 01:25 PM
wcc wcc is offline
wcc's Avatar
That bag idea is interesting but I don't think I want to try that one out.
petrolblue83911,
You drive up ramps to drain the oil. Then do you lift the front of your car to make it level? If you don't then you aren't getting all your oil our are you?
I bought a 5 gallon open top oil pan with a drain spout from Tractor Supply Company. I'll drain it all out but I really haven't heard a really good reason not to suck most of it out then drain the last couple of quarts. To suck it out and then drain it seems like to me there is less of a chance for a mess.
Bill
997.2
Old 11-11-2005, 02:03 PM
Originally posted by petrolblue83911
...the autozone large capac. catch is ok, but the problem can be that the oil comes out a bit faster than it can drain into the containers sump, so you end up watching as it rises and rises, and eventually overflows the side!
I took a doorhole bit and drilled out a 3" hole - drains great, even provides a nice wide hole for the pan plug to fall through if your not careful!
Michael D. Holloway
Old 11-11-2005, 02:06 PM
wcc wcc is offline
wcc's Avatar
Well I just finished my first solo oil change on my Porsche. I've done it on other cars and I must say that this was VERY easy. Unlike the other cars I've done there wasn't one drop of oil that landed on the floor. I mean NONE. That's a first for me!!
I ended up just draining everything into a 5 gallon oil pan I bought from Tractor Supply and it worked great!
Thanks for all the tips!!!
C-ya in the next thread........
Bill
997.2
Old 11-11-2005, 07:06 PM
