Montana 911
k9handler's Avatar
Send a message via Yahoo to k9handler
Question 2nd fender mounted oil cooler
I am thinking of getting another Mocal oil cooler and placing it in my drivers side fender...anyone know of the best way to run the lines? I am pretty sure it would be in series with the cooler I have now, just looking for pics and info on the lines (size, length, etc.) and what is the best way.
thanks
H.D. Smith
2009 997.2 S 3.8 PDK
2019 Ford Ranger Lariat FX4 Baby Raptor
2019 Can Am Renegade 1000R XC
2020 Yamaha YFZ450R
Old 11-11-2005, 08:01 AM
How 'bout this for inspiration and guidance...although it details a second Carrera-type cooler....should be close....
Two Carrera Oil Coolers for the 3.6 Finished! - LONG
- Wil
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 11-11-2005, 09:08 AM
Montana 911
k9handler's Avatar
that is what I am looking at doing...even the same color car! =o)
I need to PM Ryan and get the specs.
Thanks for the link Wil.
H.D. Smith
2020 Yamaha YFZ450R
Old 11-11-2005, 10:04 AM
I also have a second Carrera cooler like the thread by surflvr. The hardest part is sourcing the hose. A hydraulic shop had plenty of hose available that would withstand the pressure but it gets costly when you go above about 230 degrees. I cut up a pair of old fender cooler short connector hoses for 3 of the fittings and made the 90 from the 4th.by welding a length of pipe to itPorsche uses an odd size hose something like 7/8" ID so take your fittings and hose sample with you when shopping..I would place the cooler first and roughly cut the hose .With the bumper removed I ran my 2 lines,after getting 1 end crimped on each. I then marked with a band of tape the exact end length of each and removed the hose and had it cut .I pushed the end in and test fitted again before getting it crimped .One hose ends up slightly longer than the other and a little adjustment is possible by reversing them. The hose is very stiff and is hard to work with in anything other than gentle bends.
1980 911 SC 3.6 coupe sold
1995 993 coupe
1966 Mustang Shelby clone
1964 Corvair Spyder Turbo gone
2012 Boss 302
Old 11-11-2005, 04:39 PM
Montana 911
k9handler's Avatar
thank you...I have a shop here (Hydrolic Hoses, etc) that can make the hoses now that I think about it. =o) They should be able to make them as long as they have the right materials. What is the grade of hose required? 350 degree limit?
H.D. Smith
2020 Yamaha YFZ450R
Old 11-11-2005, 10:13 PM
As I used a short oil cooler hose for the fittings (about $30 new, it provides 2 fittings).I took the hose with me and asked for their equivelent. I think I ended up with some that was rated for about 275 with short periods at higher. Since the oil has already gone through one cooler ,I expect the oil going to the added one is already below the guage reading
1995 993 coupe
2012 Boss 302
Old 11-12-2005, 04:32 AM
