-   -   Rear sway bar drop link reinstall (http://forums.pelicanparts.com/porsche-911-technical-forum/250917-rear-sway-bar-drop-link-reinstall.html)
Tom '74 911 11-12-2005 04:31 PM
Hi -
I just put in new bushings for my rear sway bar, drop link included, and am having issues popping the drop link back onto the control arm. It's the delrin-like bushing that pops over a ball joint-type deal on the control arm. Is there a secret in getting this to go - other than using a BFH and some grease? I don't want to hammer on it much harder w/out some sort of permission slip.
Thanks,
Tom
Howard M 11-12-2005 04:40 PM
Mine used to pop right in with little force before I replaced it completely; maybe because I needed new plastic bushings.
Howard
billyboy 11-12-2005 05:04 PM
I think that I used a big "C" clamp and some grease, that's a little more civilized than a BFH and more controlled. this is from some one who uses BFHs all the time at work.;)
slammed1000 11-12-2005 05:29 PM
i use a large pry bar and a little leverage and pop it back into place...
campbellcj 11-12-2005 07:00 PM
definitely either a pry bar, or perhaps some large channel lock pliers. The BFH isn't as effective for this beotch of a procedure...
tsuter 11-12-2005 07:16 PM
I second the clamp method!
Chuck Moreland 11-12-2005 07:26 PM
Try warming the bushing in hot water, then C clamp and grease
Tom '74 911 11-12-2005 08:47 PM
Thanks for the replies - I'll give the clamp method a try tomorrow.
Tom
rattlsnak 11-13-2005 05:48 PM
Big Channel Locks, takes 2 seconds..
