Unhappy 911 front wheel bearing adjustment
Does anyone know how much play to leave when adjusting front wheel bearings? "Just loose enough to move the washer with a flat blade screw driver". It seems Porsche would use a specific size feeler gauge. Has anyone through their own investigation come up with a ___MM amount?
thanks
Charles
Old 06-15-2005, 11:36 AM
don911's Avatar
I've tried the move the washer method without much success. I adjust mine like any other wheel bearing. I adjust to where I can just feel slight movement when rocking the wheel (12 and 6). It's a pain to take the wheel on/off to adjust, but I can't tell crap from the washer method.
Don
24 Cayman GTS - GT Silver
23 Cayman GTS - Arctic Grey - Sold
97 993 Coupe - Arctic/Black - Sold
13 991 Coupe - Platinum/Black - Sold, 87 911 Coupe - Venetian Blue
Old 06-15-2005, 11:44 AM
911mot's Avatar
nip it up, back it off and then tighten again no more than a good hard finger tight should be ok
1984 3.2 Carrera
Impact Bumpers on track: http://www.youtube.com/watch?v=C4qbFNkdD2o
Old 06-15-2005, 11:52 AM
thanks for the help.
Old 06-15-2005, 12:00 PM
randywebb's Avatar
AFAIK, you don't use the screw driver as a feeler gauge, you use it as leverage to move the thingie...
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 06-15-2005, 12:05 PM
Designer King
Paulporsche's Avatar
Right, you should be able to just move the washer w/ the blade of the screwdriver w/o having to lever it on anything.
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 06-15-2005, 12:10 PM
I know you don't use a screw driver as a feeler gauge. You use a screw driver to push the washer from side to side. Trying to get the feel for how much pressure to use in moving the washer is the question.
That is why it seems Porsche would use a feeler gauge. Like .004,.008, etc, between the washer and the locking nut.
Old 06-15-2005, 12:57 PM
450knotOffice's Avatar
It really has more to do with friction then gap. There really is no gap to measure, just how tightly the nut is snugged down on the washer.
Old 11-23-2005, 12:07 AM
