Question Very rough idle??
I have a problem with my 1987 3.2. The idle is very bad when I crank it. Any Ideas? Sensor? Do I need to put in an gas additive??
76 911S
82 911SC Targa (Hot Rod In The Making)
Old 11-17-2005, 10:57 AM
ianc's Avatar
Bad in what way? Low? Missing? Write a 2 page essay explaining in exhaustive detail your idle observations. And, I hope you're not cranking it while you're idling.
ianc
BMW 135i. Nice. Fast. But no 911...
"I will tell you there is a big difference between driving money and driving blood, sweat and tears." - PorscheGuy79
Old 11-17-2005, 11:19 AM
ausdilecce's Avatar
Is the idle 'hunting' ?
Going from say 800 to 400 to 1300 to 400 then stabilizing at 800 ish until the next time you touch the throttle ?
Does it happen all time time or only when hot or only when cold ?
1987 ROW Carrera Targa, SW chipped
1983 U.S.A. SC coupe ( bro has her now )
Old 11-17-2005, 11:35 AM
Im not sure if the engine is idling bad if the weather is hot or cold...just put it in my 76 911s. Its been cold everyday that the engine has been in. As far as RPMS, I haven't figured out how the wiring yet from the 76' to the 87 tach (THATS A WHOLE OTHER TECHNICAL ISSUE I'M HAVING). The idling is low and missing and will even go dead unless I give it some throttle quickly after starting. After that however, the miss is not as bad, but is still there.
76 911S
Old 11-17-2005, 04:34 PM
Driving member
jester911's Avatar
Assuming you have checked for spark on all cylinders, you may need to adjust the idle screw and or the air/fuel mixture.
Do a search and you will find tons of info on idle problems.
Jerry
'86 coupe gone but not forgotten
Unlike women, a race car is an inanimate object. Therefore it must, eventually, respond to reason.
Old 11-17-2005, 05:48 PM
WydRyd's Avatar
Apart from the idle, how does it run otherwise?
If it's ONLY a poor idle, then check for vacuum leaks, O2 sensor, Cylinder Head Temp sensor.
Merv
'89 911 Turbo Cab
Protomotive MAP ECU, Twin Plugged Heads, GT2-EVO CAMs, 3.3L fully finned P&C's, ARP fasteners, C2T head gaskets, Titanium Retainers, Turbo spec valves, springs & guides, 964 splash valves, GT35R BB turbo, GSF Stainless Headers, Magnaflow Exhaust, Full bay Intercooler, TiAL 46mm w/gate, TiAL 50mm BOV, Apexi AVC-R EBC, SPEC Stage3+ Clutch kit, Crane CDI Ignition
Old 11-17-2005, 06:06 PM
sagacis's Avatar
I had rough idle. Turned out the #6 spark plug wire had come loose. I probably would have had rough running, too.
Mark Arvidson
1981 911SC Targa
Old 11-17-2005, 06:19 PM
These engines will idle with 2 cylinders not firing, not well but they will run. Start by pulling plug wires one at a time. To prevent shock, remove one wire then fire up the motor. If things are worse reconnect that wire and go to the next one. Chances are you may have 2 wires reversed in the firing order.
Another thing you can do is pull all of the plugs after runnning for a minute or two. You're looking for wet plugs or really black plugs compared to light brown to brown. Two black wet plugs could be reversed.
Remember the rotor turns clockwise, 1-6-2-4-3-5.
Double check the wires to the coil, couldbe reversed.
Vacuum leak is also a definite maybe.
How about timing. Check it with a timing light.
If all else fails, check each cylinder with a compression guage.
Hang in, you'll find it.
DOUG
'76 911S 2.7, webers, solex cams, JE pistons, '74 exhaust, 23 & 28 torsion bars, 930 calipers & rotors, Hoosiers on 8's & 9's.
'85 911 Carrera, stock, just painted, Orient Red
Old 11-17-2005, 06:39 PM
You might want to search the archives for ICV (Idle Control Valve), and try cleaning it out with Isoprophyl alcohol (particularly if the engine was out of the car for a while). That helped my 'hunting idle' issue....
edited to add this link:
Idle drops after 20 secs on a 3.2?
Old 11-18-2005, 04:48 AM
