78 wakeup
what airbox upgrade ?drill holes where to upflow?
Old 11-17-2005, 07:21 PM
you see Arthur...
jasonlee's Avatar
Its pretty hard to improve on the stock air box for air flow. Porche designed it to maximize air flow. Your upgrade dollars could be better spent elsewhere, more free flowing exhaust, suspension etc. Just my $0.02
J
82 911 SC, Cat bypass, Flowmaster 1 in 2 out lightweight flywheel and backdated heat
06 Cayenne S
00 ML 55 AMG
Santa Cruz Bullit
Old 11-17-2005, 08:12 PM
rpiper's Avatar
I wouldn't bother. The 8.5:1 CR 3.0L already gets more air than it needs through the stock airbox. I have a 3.0L w/ euro P/Cs, 964 cams, SSIs. When I dyno'd, I did one run with the factory setup then one with the cover completely removed and the filter just held in place with straps and there was NO discernible difference. Not even .3 hp. Plus if you drill the airbox it will allow water to enter when it rains.
Bob Piper
78 911SC "Bullseye" SOLD
00 540i
02 CBR 954RR
98, 00, 03 sons
Old 11-18-2005, 08:25 AM
Paper Member
Bobby, What kind of gains did you see when you dyno'ed? How different does your car feel now?
Enemy of the State
Brandolini’s Law: It takes hours more time, research, and writing to debunk misinformation than it takes to spread it.
Old 11-18-2005, 08:45 AM
