Unhappy Found a sporto coupe
But the transmission slips in all gears. Is it safe to drive? I assume the seals need to be replaced oil is probably seeping into the clutch. Also any sporto mechanics in the Maryland area to fix this?
Old 11-18-2005, 01:08 PM
kqw kqw is offline
You're kidding right? There must be a great story around why you want a Sportomatic.....
The Fox
Carrera
Old 11-18-2005, 01:46 PM
B D B D is offline
B D's Avatar
Not really how bad is the slipping it's normal to have some slip to about 2800 RPM. Once enough oil is on the clutch its over you will need a tow home.
68 911L
Old 11-18-2005, 01:53 PM
