Sorry for the easy question, but where would the throttle body be located on a 3.0 litre SC engine? I was in auto shop class this morning and I got a chance to work on my 911 and the shop teacher suggested a BG product that cleaned the throttle body. Other than that, I got a chance to add a can of BG Induction System Cleaner to the fuel. This stuff works great! I just couldn't find the throttle body to add that other cleaner to it!
Matt '76 Porsche 911 with '78 3.0 SC engine '71 VW Bus '14 VW Passat (toddler hauler & wife approved ride) '03 Subaru Baja original yellow & silver |
Formerly bb80sc
Open the black air box cover, remove the filter and you should be able to look back in there and see it.
Cheers -Brad 2015 Cayman GTS 2015 4Runner Limited |
Somatic Negative Optimist
Follow the throttle linkage to where it actuates the throttle shaft. The inside of the throttle body is only visible when removing the black, soft bellow/boot on top. (It has 2 large clamps to hold it down)
Just removing the air filter is not really showing the throttle body; it'll show you just the air sensor plate/lever. Be careful with any additives; Porsche doesn't recommend any. Just adding injector cleaner into the gas tank now and then is good. The throttle body needs no cleaning, just get a new airfilter to keep the dirt out. As a novice, don't overfill the engine oil! If you find oil inside the airbox (Under the airfilter) you may have overfilled. Keep the level midway on the stick when hot and running, not more than midway!
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD! 1995 seafoam-green 993 C2, LSD, Sport seats. ![]() Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ". ![]() |
LOL. Thanks bb80sc and Gunter. I've read quite a few "I've overfilled my oil tabk posts" so thanks for the reminder. I'll take your advice then and not add any additives to the throttle body. By the way, here is the induction system cleaner I used:
![]() This stuff is great! Maybe Wayne has some here on his site.
