-   -   MFI question (http://forums.pelicanparts.com/porsche-911-technical-forum/252137-mfi-question.html)
c911s 11-19-2005 02:44 PM
MFI question
69 pump - posts on MFI adjustment proceedures seem to indicate that there is a gasket between cover and pump body at outside end of thermostat; is this so? is it available ? what thickness/material for making one? thanks
304065 11-19-2005 05:08 PM
There IS a gasket-- no part number listed for it in PET, however. It's not rubber or cork, more like thick paper, but can't be more than about .10 mm thick. Unfortunately I don't have a micrometer, or I'd pull off my thermostat and measure.
The thickness of the gasket is critical to the correct warmup mixture.
Grady Clay 11-19-2005 05:18 PM
John.
You are absolutely correct. That simple gasket partially determines the thermostat shut-off characteristics. There needs to be a standard for that. If nothing else, measure your existing (original?) gasket and make a new one the same thickness.
The differences shouldn’t effect the fact that the thermostat shuts off, just when. The thicker – the later, but richer in the process. Err on the lean poor running side.
Best,
Grady
c911s 11-19-2005 07:50 PM
thanks for the quick reply guys
I do not have a gasket at this location, reason for the question. Am in process of cleaning the thermostat discs etc....
c911s 11-19-2005 09:12 PM
FYI - photos of the discs during clean up, thermostat housing pre and post cleaning - made a paper gasket for the end, can not hurt to try...http://forums.pelicanparts.com/uploa...1132463472.jpg http://forums.pelicanparts.com/uploa...1132463494.jpg http://forums.pelicanparts.com/uploa...1132463512.jpg
svandamme 11-20-2005 01:59 AM
in case your pump needs new gaskets for the shutoff solenoid, or for the idle adjust plate... i used black sillicone (leftover from the PPengine rebuild chemicals kit) in that area, and it worked really well , just a bit difficult if you need to apply it with the pump mounted in the car...
David E. Clark 03-01-2006 02:52 PM
Please take a look at the Ultimate MFI resources thread and add your links and resources. It will make a great resource for all of us. SmileWavy
