MFI question
69 pump - posts on MFI adjustment proceedures seem to indicate that there is a gasket between cover and pump body at outside end of thermostat; is this so? is it available ? what thickness/material for making one? thanks
Old 11-19-2005, 02:44 PM
304065's Avatar
There IS a gasket-- no part number listed for it in PET, however. It's not rubber or cork, more like thick paper, but can't be more than about .10 mm thick. Unfortunately I don't have a micrometer, or I'd pull off my thermostat and measure.
The thickness of the gasket is critical to the correct warmup mixture.
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 11-19-2005, 05:08 PM
Grady Clay's Avatar
John.
You are absolutely correct. That simple gasket partially determines the thermostat shut-off characteristics. There needs to be a standard for that. If nothing else, measure your existing (original?) gasket and make a new one the same thickness.
The differences shouldn’t effect the fact that the thermostat shuts off, just when. The thicker – the later, but richer in the process. Err on the lean poor running side.
Best,
Grady
ANSWER PRICE LIST (as seen in someone's shop)
Answers - - - - - - - - - - - - - - - - $0.75
Answers (requiring thought) - - - - $1.25
Answers (correct) - - - - - - - - - - $12.50
Old 11-19-2005, 05:18 PM
thanks for the quick reply guys
I do not have a gasket at this location, reason for the question. Am in process of cleaning the thermostat discs etc....
Old 11-19-2005, 07:50 PM
FYI - photos of the discs during clean up, thermostat housing pre and post cleaning - made a paper gasket for the end, can not hurt to try...
Old 11-19-2005, 09:12 PM
Gon fix it with me hammer
svandamme's Avatar
in case your pump needs new gaskets for the shutoff solenoid, or for the idle adjust plate... i used black sillicone (leftover from the PPengine rebuild chemicals kit) in that area, and it worked really well , just a bit difficult if you need to apply it with the pump mounted in the car...
Stijn Vandamme
BIMDIESELBMW116D2019
Old 11-20-2005, 01:59 AM
Autodidactic user
David E. Clark's Avatar
Please take a look at the Ultimate MFI resources thread and add your links and resources. It will make a great resource for all of us.
Please help the MFI community keep the Ultimate MFI resources thread and the Mechanical fuel injection resource index up to date. Send me a PM and I'll add your materials and suggestions.
1973 911E Targa (MFI)
Old 03-01-2006, 02:52 PM
