Heat Exchanger Clean Up
I pulled my heat exchangers and am looking for some direction as to how to clean them, any advice? Hot tank? Bead blast? Oven cleaner? What about fumes down the road? Also what material are the HEs made of? They are off a 1987 911.
Bill
1987 Marine Blue 911 Carrera Coupe RIP 01/2011
1987 Black 930 RUF Coupe Resurrected, 2488 lbs, EFI Technology, UMS Tuned - Mild & Wild, Current in pieces at paint
Old 11-20-2005, 08:54 AM
GOT TURBO..
MobileWrks's Avatar
Simple green concentrate. A wire brush if bad
Old 11-20-2005, 05:56 PM
During this summers rebuild I took the opportunity to bead blast them clean. They still were showing ther age so figured what the .... I'll paint them with the silver 1500 degree paint I had left over from the cam covers. Three coats cured in the oven (with wifes OK but the fumes were pretty bad) and they came out great. Even the cross over pipe is still looking great after three months as is the cat bypass pipe.
1987 911 Guards Red Targa, nearing 200,000 miles, lowered, 7's & 8's, 964 grind cams from John Dougherty, A.P.E. Mass Flow Sensor with chip to match, cat bypass, strut brace, dual out muffler. Will consider newer model in 8 years when I turn 75 and then maybe not.
2012 BMW 528i (wife's)
2007 Toyota FJ (rain and off road days)
Old 11-20-2005, 08:22 PM
If the interior received oil drippings I'd suggest a radiator repair shop for an acid dip.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 11-20-2005, 10:48 PM
