-   -   Part # (http://forums.pelicanparts.com/porsche-911-technical-forum/252361-part.html)
Ron.G 11-21-2005 04:04 AM
Part #
does anyone have the part number for the small aluminum washers that go on the chain tentioner banjo fitting?
I need the ones that go on the small fittings on the timing chain case.
I ordered from Pelican but got the wrong ones.
Jadams1 11-21-2005 08:27 AM
900-123-005-00-OEM $1.25 ea. from pelican. Is your car on the road?
Ron.G 11-21-2005 09:10 AM
The car is not on the roard just yet. I still have some more rust to bdeal with.
I'm hoping for spring, but I've gotten alot done so far.
Thanks for that part number.
Ron.G
Jadams1 11-21-2005 09:35 AM
Ron, I gave you the wrong part number.
The correct p/n is 900-123-115-30-OEM @ $0.75 ea.
The other part number iI gave you is for the bango fitting crush washer at the cam tower end. Sorry about that. Good luck on the rust war.
John
Ron.G 11-21-2005 10:04 AM
I thought that number looked formilliar, Thats what I ordered from Pelican. The second number you gave me is the one that I needed.
Ah rust...........
