Klub Sport race at Daytona
I had a great time at the HSR event at Daytona,one question for anyone that races this event-why does almost every 911 run a T front lower spoiler?Are they more aerodynamic than an S spoiler or is it a rule they must comply to?Just wondering because im in the process of building a 69 to run in HSR next year and could not find anywhere in the 2005 rule book it was required.Thanks
Old 11-20-2005, 06:20 AM
Alter Ego Racing
ErVikingo's Avatar
Spoodup,
if I remember correctly, aero configuration is limited to 1969 specs. Most of us go to R spec nose to get the vents (not a T nose). FYI, I believe a front center grill is not allowed (thus most of us run dual coolers - on either fender instead of a center mounted one).
No other aero modifications are allowed on 911's although some have shaved the gutters and installed flush glass which was I believe grandfathered to allow some guys/ cars to participate.
Drop me a line if you have further questions.
International GT Champion; Porsche GT3 Cup Trophy Champion; Klub Sport Challenge Champion; Rolex Vintage Endurance Series Champion; PCA Club Racing Champion; National Vintage Racing Champion
Old 11-20-2005, 12:47 PM
Alter Ego Racing
ErVikingo's Avatar
You can get the rules a klubsportracing.com or at hsrrace.com
Old 11-20-2005, 12:48 PM
Thanks for the info!
Old 11-20-2005, 02:42 PM
Alter Ego Racing
ErVikingo's Avatar
I got the rules in my office, let me know if you have any questions. Cheers, Juan
Old 11-20-2005, 07:23 PM
Alter Ego Racing
ErVikingo's Avatar
Here's an extract:
2005 KLUB SPORT CHALLENGE RULES
Professional Drivers will not be awarded points for year end awards. Klub Sport will
determine pro or amateur status.
There will be strict conformance with regards to race cars qualifying to participate in the
race.
The winner of the Friday afternoon Challenge Race must submit his/her car to the Klub
Sport Paddock area for technical inspection.
Two other top 10 finishers will be chosen at random for inspection as well.
Engine size, brakes, body work, tires and suspension will be inspected.
If a car is tagged due to non-compliance of the Challenge Rules and technical
specifications, the car will have until the next Challenge Race to comply or be
disqualified for the year.
No points or prizes will be awarded until a vehicle is in compliance.
Immediately following each Challenge Race, there will be a Race Participant Social at the
Klub Sport Paddock area for presentation of the Awards.
FUEL AS PER HSR RULES. FUEL USED DURING A KLUB SPORT
CHALLENGE RACE WILL BE TRACK SUPPLIED RACE FUEL OR
PREMIUM PUMP GAS OR EQUIVALENT. NO OXYGEN ENRICHED FUEL
OR “EXOTIC FUELS”.
Driver must qualify car or start from the rear of the field.
2.0 LITER 911/914/6 PORSCHE
ENGINE
1. 2.0 Liter 81mm Bore Maximum X 66 mm Stroke
2. Weber or PMO Carburetor up to 46 mm or Bosch Mechanical Injection as supplied on 1969 911S
3. Distributor or Crankfire – OK
4. Twin Plug – OK
5. Heads are to be original 2.0 Liter components. (45mm Intake Valve, 39 mm Exhaust Valve maximum diameter.)
TRANSMISSION
1. Factory - Supplied Gearbox as per year of manufacture. – 5 Speed
2. 901/911 Transmission – OK
3. Gear Ratios – OPEN
BODY
Body to remain stock up to 1969 configuration
stock 914-6 GT body work is ok
1. Up to 1969 911 Front Bumper Required
2. Tub to remain stock - bolt-on Panels/Material – FREE
3. 1,800 lbs. Minimum Weight, no Driver.
4. Tube Frame Chassis – ILLEGAL
5. Dzus Fastened Panels (Exterior Panels) – ILLEGAL
6. 914 Windshield or Roadster – OK
WHEELS
8" x 15" maximum width and diameter Rear
7" x 15" maximum width and diameter Front
TIRES
1. 225 X 50 X 15 Maximum Size Radial Rear
2. 205 X 50 X 15 Maximum Size Radial Front
3. 50 Series Lowest Profile
4. Street DOT Radial -or- Vintage DOT Tire, ie: Dunlop, Hoosier, Goodyear or Avon (HSR Approved Tires Only)
SUSPENSION
1. The Suspension must be exactly as fitted by the original manufacturer as to type and location.
2. Coil-Over Springs and Remote Reservoir Shocks PROHIBITED
3. Anti-Sway Bars FREE
4. Bushing Material FREE
5. Torsion Bars FREE
BRAKES
1. Brakes up to 1973 – ALLOY FACTORY SUPPLIED CALIPERS AND ROTORS.
2. 1978 911SC Front Caliper (Cast Iron A Calipers) may be substituted for Front Alloy.
Old 11-21-2005, 06:43 AM
Juan,I really appreciate all the help on this matter-Have a great hoilday and send some warm air up here when you can!Thanks again,Mark
Old 11-21-2005, 08:02 AM
Porsche Doc's Avatar
Man HSR Racing is a blast! D
We have not raced HSR since the fall race at Atlanta in 2004.
We had been racing HSR for the previous 5 years.
We have a 2.0L 914-6 GT and we always ran the Klub Sport races. Its great competition! Not to mention its a FREE race!
I am glad to say in 2006 we will be returning to HSR and The Klub Sport races. We will only run about four or so HSR races next year starting with the Mitty in Atlanta in the spring.
We will run a couple of SVRA races to now that they allow crankfire ignitions.
I am realy looking forward to it too.
I hope to see you guys there.
Thanks!
Don Ramsay E Mail: aircooledclassicsporsche@gmail.com
The father of 964 Backdating!
www.aircooledclassics.co
www.facebook.com/AirCooledClassicsPorsche/ www.instagram.com/aircooledclassicsporsche/
Old 11-21-2005, 08:39 AM
Plavan's Avatar
Don how did that "M" gear treat you?
Chad Plavan
911ST Race Car/2.5L SS Race Motor #02
1972 911T- Numbers matching- Restoring to stock
2011 Porsche Spyder Wht/Blk/Carbon Fiber Buckets/6-Speed (Sold)
2016 Elan NP01 Prototype racecar- Chassis #20, #02
Old 11-21-2005, 09:50 AM
