-   -   3.2 ICV question (http://forums.pelicanparts.com/porsche-911-technical-forum/252422-3-2-icv-question.html)
Purkinjefibre 11-21-2005 12:40 PM
3.2 ICV question
Hi Pelicans, I am well into my megasquirt EFI project and coming up with many questions. Todays pressing question is, what kind of "valve" is the 3.2 Idle Control Valve. Is it a stepper motor or just an open closed switch?
thanks guys
ianc 11-21-2005 07:08 PM
If I knew I'd tell ya, but I don't, so you'll just have to settle for a bump,
ianc
Purkinjefibre 11-22-2005 06:28 AM
Ok
Nudge nudge, wink wink, say no more...
greglepore 11-22-2005 07:03 AM
Not sure-it definitely isn't either "open" or "closed"-it occilates between those states. Does that help?
Purkinjefibre 11-22-2005 07:26 AM
Ok
Thanks Greg, sounds like a stepper motor?
rick-l 11-22-2005 09:49 AM
From the reading I've done (no experience) the DME sends a variable pulse width signal (ground closures) to the rotary solenoid on the valve. This current pulse train creates a magnetic field in the valve (looks like + and -, must have a default position at neutral?). The period of this pulse train is fast enough so that the dynamic variables in the valve (inductance, inertia, etc) average it out and it is a somewhat steady value i.e. it stays in one place.
The idle speed is a closed loop control with the DME. The DME doesn't "know" where the valve is positioned it just "knows" it wants more or less idle speed and reacts accordingly.
gadszucs 11-24-2005 10:09 AM
It's a PWM valve just like the VW's...fully supported with MS but may need a higher rated transistor to handle the current, especially on the V3 ECU's. Talk to Dave at www.fireandfuel.ca for more information as he knows these systems inside out.
